Could someone tell me the toque specs for the 3 bolts that connect flex disc to Transfer case output flange on a 09 E61? There are bunch of specs for that on BMW TIS which is confusing. Realoem shows hex nuts while mine are E-torx
Have to check on that, remember using E12 socket on those.
Another question, do you have to really replace all those bolts that goes with flex disc? I know BMW says to replace every bolt even for non aluminum ones. Mine are super clean and no rust at all.
