| Wagon61 |
Oct 1, 2020 04:57 AM |
E61 stalls
Hey everyone , I am new here. I am own a 2006 E61 with winter package. Usually the car drives great but the other day it started stalling when idling and sputter when driving at times. When I arrived home I pulled out the Foxwell and scanned the car the following codes appeared: 2E7C BSD DATA BUS COMMUNICATION FAULT, 2E81 DME ELECTRICAL COOLANT PUMP SPEED DEVIATION, 2E8B INTELLIGENT BATTERY SENSOR MISSING, 2EA1 OIL CONDITION SENSOR MISSING. I am aware that the BSD connects all of these items and if one is bad it affects the other. My water pump and thermostat was replaced when I purchased the car in April of this year and I can read my oil condition on the display. I started troubleshooting what I thought might be the culprit the IBS. I disconnected the IBS from the DME/BSD connector cleared the codes waited and rescanned now the only code that appeared was 2E8B INTELLIGENT BATTERY SENSOR MISSING. I assumed this was the issue and moved forward ordering a new IBS sensor and installed it, I took the car for a drive with the new IBS installed only for the car to sputter and then completely stall when I arrived home. When I attempt to start it the engine just shuts off , once again I rescanned this time the only code displayed is 2E7C BSD DATA BUS COMMUNICATION FAULT. I really need help resolving this, I hope someone can help me make sense of this its driving me crazy. Thanks in advance.
