E61 Panoramic Roof - Seal/Wind Noise
Old Jun 3, 2016 | 01:22 AM
Martin Robinson's Avatar
My Ride: Car
Post E61 Panoramic Roof - Seal/Wind Noise
I'm starting to address a few issues with my recently acquired (second) E61. Maybe some of what I know will be helpful to others, and I'd appreciate any experienced commentary and suggestions.
Situation: The panoramic roof generates high wind noise. The seal appears to be perished, with a rough surface.
Background: This is a well documented problem but it's taken some searching to find the right approach. I've seen removal of both panels and other parts advocated, or not removing them at all. Here, however, is the BMW service instruction, which specifies only removing the rear panel and looks mainly straightforward (but see below)
http://www.slideshare.net/Slegt70/25...ltsunroofframe
The replacement seal is slightly bulkier than the original and has a reinforced surface. The packaging states that recoding is necessary with fitment. Since this isn't mentioned in the service instruction, I suspect that a newer instruction must exist. Also, there is a strip of seal on the leading edge of the rear panel which looks an equally valid candidate for replacement with the same part, but there is insufficient length to do both. This must be a separate item. The instruction makes reference to applying an adhesive in addition to the self adhesive backing of the seal.
Is this really a DIY job, or a step too far - coding, contact adhesive, alignment? Has anyone successfully done this, or knows how much a dealer charges?
Solution: TBC!
Old Jun 3, 2016 | 10:04 AM
MiniNL's Avatar
My Ride: 2008 BMW 535XiT Sport Wagon
Recoding the sunroof basically consists of the sunroof finding the new points at where it's closed. Otherwise it may not close, because it thinks something is being pinched. I think it's pretty easy. From what I understood you have to press the sunroof button (for venting) for about 15 secs or so.
Old Jun 3, 2016 | 10:08 PM
My Ride: Car
Default Panoramic Roof Coding
Thanks for the tip, which may well be needed.
The following video seems to describe that process and echoes the procedure I've used before on E46s.
However, I think things have moved on and new models, including E6X, have a much greater degree of vehicle management:
http://www.m5board.com/vbulletin/att...roof-noise.pdf
It could be that I get the seal fitted, but need a dealer to code it to close properly.
Old Jun 4, 2016 | 07:30 PM
MiniNL's Avatar
I'd give the button a try first . Can even do it without installing a new seal. If it doesn't work, no harm, right.
Old Jun 5, 2016 | 06:43 AM
Mrmandmman's Avatar
My Ride: 535xi touring
I recently replaced mine:
http://www.bimmerfest.com/forums/showthread.php?t=878012&highlight=colorado+wagon
Old Jun 6, 2016 | 08:50 AM
BostonJon's Avatar
My Ride: BMW 530xiT (E61)
another good thread...there seem to be quite a few people that install the new seal with the sunroof CLOSED to get everything aligned and then slowly remove the tape to expose the adhesive
https://5series.net/forums/e61-touri...-fixed-115159/
Old Jun 6, 2016 | 02:20 PM
Lotus99's Avatar
Thanks for posting the link to that thread.
I was going to tell the OP to do a on the forums, as I remembered there was already a comprehensive thread on it, along with a service bulletin that I had uploaded in it.
With these cars being the age they are, almost everything has pretty much already been well documented here in our forum.
Old Jun 6, 2016 | 03:52 PM
BostonJon's Avatar
well said. and that is exactly what gave me the confidence to buy my 9-year-old E61 a few months ago. it's been a tremendous resource for all the little quirky things that go wrong with these cars.
Old Jun 24, 2016 | 08:02 AM
RCB's Avatar
RCB
My Ride: E61 535Xit
I ordered a new seal earlier this week. I had a hard time finding one in stock, most places were back ordered with no ETA.
I'm really looking forward to eliminating the wind noise!
16g-95gsx
Nov 12, 2015 01:46 PM
JonathonK
Aug 25, 2015 03:30 PM
PMorganRacing
Aug 17, 2015 02:31 PM
dvw
Jan 12, 2005 06:20 PM
