E61 n52 misfire no codes
My Ride: 2006 530xi wagon
So I’ve got a misfire with no codes. I’ll attach an image of what the “smooth” running values look like during a misfire. I’ve recently done coil packs, spark plugs, whole pcv system, valve cover gasket, and vanos solenoids. Still not fixed. Any ideas?
did you readapt the engine after the replacements?
the only thing left is the injectors, if you have INPA you could check the rough running graph
moto.dev
08-29-2023 06:16 AM
Christian Paul
12-07-2019 04:39 AM
BurtonSnol3order
02-05-2019 10:58 AM
