e61 lowering
My Ride: 525d amethyst grey
Here is what the INPA menu looks like. It's under the main E60 menu then suspension -> single axle
I had a lot of headache getting INPA to work, one important tip is to have the USB cable that connects to the OBD port set to COM1 on the windows machine and set latency to 1 ms.
Here are a few tips on adjusting ride height.
1. Once you start lowering or raising it won't stop so be ready to hit the F9 (OFF) button when you reach your target.
2. Each side sort of adjusts together, despite having separate controls the software doesn't let you get too far away from the value of the opposite side before it starts compensating in the same direction. In other words you will have to play with both sides up and down the scale to arrive at a equal levels for both sides.
3. In the previous menu to the one shown, make sure Energy saving mode is off and production mode is on. My understanding is that the settings don't remain in memory unless these modes are set this way.
![](http://s18.postimg.org/qjkuw5495/inpa.jpg)
My Ride: e61 / KW V3 / JB4 / M5 Rear Sway / FDL Coded / SAT Retrofit w GKE flash / ER FMIC / BMS DCI
Model Year: 2010
Engine: N54
Just about everything you need to know is in this thread, or linked from this thread:
Diagnostic Help: Odd scenario with rear suspension. INPA leveling vs. KW links
My Ride: 535d
Model Year: E61 2006
Or you can just tilt the height sensors to fool the system. We played with it while doing the wheel alignment on the machine to achieve the best looking vs friendly camber to improve tire wear.
romelrod
15
02-19-2016 10:25 AM
reddv1
01-05-2016 01:15 PM
