My Ride: '04 E61 525d
TITANGRAU II METALLIC (A36)
LEDER DAKOTA/BEIGE 3 (LCBA)
SIDE AIRBAG FOR REAR PASSENGERS
ALARM SYSTEM
ROOF RAIL
SUNBLINDS FOR REAR SIDE WINDOWS, MECH
FLOOR MATS, VELOUR
INT/EXT RR VW MIRROR W AUT ANTI-DAZZLE
INTERIOR RR VW MIRROR W AUT ANTI-DAZZLE
WOOD TRIM
CUPHOLDER
SEAT HEATING F DRIVER/FRONT PASSENGER
HEADLIGHT WASHER SYSTEM
PARK DISTANCE CONTROL (PDC)
XENON LIGHT
ADAPTIVE HEADLIGHTS
AUTOMATIC AIR CONDITIONING
CRUISE CONTROL
NAVIGATION SYSTEM PROFESSIONAL
CAR TELEPHONE PROFESSIONAL
CD CHANGER BMW FOR 6 CDS
Ebay.de
About 580? per set I believe. Or maybe a second hand set locally?
I'm guessing in NCS-Expert you disabled the check-control on the rear lights (Kaltuberwachung-Warmuberwachung) to avoid strobing? Is there anything else that need to be recoded? I guess not...
The led bars, do they take 12V or is a resistor needed in the wiring to lower the voltage on them?
Is a resistor needed over the turn indicators to make them blink in a normal fashion (not fast as if one is broken)?
I'm also thinking of retrofitting the LCI tails for a while now but the price of the lights and an additional module is a little over the budget I want to spend on it. So I was thinking of doing it in a similar way as you did. Nice to see it's working out for you.
No resistors needed after proper NCS coding.Now I seeking any original LCI car to see what is the brightness of LEDs strips.
Pre Lci dipped/parking not working after lci tail lights install.
Ive retro fitted, the tail lights on my 61. Everything works OK. The LED bars , break light reverse indicators and fog lamp. All good has been programmed,
but i've i've got an issue on my pre Lci xenons headlamps, where the inner dipped beam does not work. And the car comes up, we ve parking front left and right failure, but the xenon lights as they should.
is there anymore programming that need to be done to sort this out.
I've heard the time creation date needs to be changed
