5Series.net - Forums
-   E61 Touring Discussion (https://5series.net/forums/e61-touring-discussion-4/)
-   -   E61 LCI tail lights retrofit any news? (https://5series.net/forums/e61-touring-discussion-4/e61-lci-tail-lights-retrofit-any-news-120669/)
bmwspeed Jan 26, 2012 11:27 PM
2 Attachment(s)
I allready posted : http://forums.5serie...30#entry1415355
but there is true E61 forum so I think e61 owners spoted there :)
Attachment 129895
Attachment 129896
Any advices how to connect these lights: enough coding? Need some add wires to tail ? for LED signal ? what about hatch part ?
Thank you.
Theo Jan 26, 2012 11:38 PM
You can get the necessary plug&play* cables from member Bruce_miranda (site).
Here's a nice DIY on installing those cables.
* No coding required whatsoever...
bmwspeed Jan 27, 2012 04:18 AM
250 POUNDS???? FOR DIY ?????THANK YOU ....I MAKE SOLUTION MYSELF.
P.S Nothing personal ! Thank you for the links !
Ricapar Jan 27, 2012 04:22 AM
That's the spirit! :twoup:
Theo Jan 27, 2012 04:30 AM
Suit yourself, in that case however: be sure to re-pin the X329 and X328 pins to the K2 and L2 connectors, otherwise you'll get capitals only...
narvselius Jan 27, 2012 09:09 AM
Interesting attitude... :whistle:
bmwspeed Jan 28, 2012 01:10 PM
Ok ! One evening for understand who is who in schematics.Afternoon to solder new wires from older connectors to LCI taillights and evening to check out LMA 1 coding and do some tricks with NSCexpert.
Tomorrow I`ll go for hatch lights part(its not e60 its e61)-more work to do.Now the main tail lights working good.No errors no strobing.
bmwspeed Jan 30, 2012 10:20 AM
3 Attachment(s)
Soldering hatch led taillights E61.
Bimmerstyle Jan 31, 2012 12:53 AM
I'm guessing in NCS-Expert you disabled the check-control on the rear lights (Kaltuberwachung-Warmuberwachung) to avoid strobing? Is there anything else that need to be recoded? I guess not...
The led bars, do they take 12V or is a resistor needed in the wiring to lower the voltage on them?
Is a resistor needed over the turn indicators to make them blink in a normal fashion (not fast as if one is broken)?
I'm also thinking of retrofitting the LCI tails for a while now but the price of the lights and an additional module is a little over the budget I want to spend on it. So I was thinking of doing it in a similar way as you did. Nice to see it's working out for you.
Mobmatrix Jan 31, 2012 05:25 AM
I am also wondering about upgrade my "tail" til LCI
But i cant find anywhere to buy the taillights other that BMW, do any one
know a cheaper place ?
