E61 6spd Winter Wagon
#21
Tires are only 245 width; I ran the same width last year (we use the 225/235 combo on our E90s and i've used 235s on the previous volvo for winters). Have yet to have to be stuck anywhere or wish for narrower.
Also I've driven a lowered car in the winter for the last decade; I'm not sure why that would be an issue?
#22
My Ride: E61 530xi 6MT
Engine: N52
I still don't see the big deal. Even driving up to northern Quebec or Vermont for snowboarding. never had an issue;. When there is snow, its either plowed or its still fluffy and you just push it along; I'll never be taking the car off paved roads.
Lowering this car Id be going around an inch down(ideally), that's about the height of the stock sport/M-sport suspension for rwd cars. Is that too low to winter drive even if its factory? Plus, I'm willing to bet there will still be more wheel well & ground clearance than many compact or sports cars you see driving around in the winter. That extra inch is going to be a huge killer...
Drifter2090 (07-03-2023)
#23
#24
Thanks! I've been working on the steering a bit more and this is what I've come up with; Still a little light at parking lot speeds but the rest is pretty good. As close to the amazing steering feel that the E90 chassis has:
GESCHWIN_WERTE_KOMFORT_KGM
Wert_02
Wert_03
Wert_06
STROMWERTE_KOMFORT_KGM
Wert_02
Wert_03
I'm also still trying to find if I can turn on the throttle(EDK) setting for sport mode without pressing the button. I'm searching all the modules still.
Wert_02
Wert_03
Wert_06
Wert_02
Wert_03
You mention sport mode, have you tried flashing the TCU to sport mode? I've googled around and read that 7601458 gives the transmission sport programming without the added shifter/hardware.
#25
Engine: N52
This sounds really cool, how are you accomplishing this? Is it a simple NCSexpert/NCSdummy job, or is there more to it?
The TCU is the media box; That handles bluetooth, phones and gps kind of things, Do you know that flashing that would affect the rest of the car?
#26
I'm happy with the improvement, but am curious how you are forcing it to be 2, 3, and 6?
TCU, not ECU. I just realized you have a manual transmission, so this does not apply. I went ahead and did it just now, it loaded just fine and I will see if I notice anything when I drive it.
#27
I fail to understand what changes are happening with these settings. As far as I’m aware all North American E61’s have xDrive and no dynamic drive or active steering so I figured we had a standard power steering system. Did I miss something in one of your upgrades?
#28
Engine: N52
We don't have active steering(adjustable ratio) but North American E60s have Servotronic(adjustable assist) standard; What I am adjusting is the amount of assist. Trying to change it from a prius like light and easy feel, back to the bmw heavier and responsive sporty steering feel. But doing it normally so I don't have to press or install a sport button
kd7iwp (11-23-2020)
#29
Engine: N52
Started doing the rear brake overhaul. I also needed one of the hub bushing/bearings replaced; Jesus they are a pain to get in and out. I know they are press fit but aluminum+steel really do stick together. Also getting the axles out of the hub; 1 tapped out nice while the other had to be taken off and pressed out. Also noticed one of the upper control arm boots looked a bit.
I went with the #820 Z8/M5 upgraded front upper arm and stock rear arms as they are the same. I also got new dust shields as mine seemed to be corroding where they get bolted; kinda sloppy. But the nice thing is all wagons have the same dust shield, 320 or 345 rotors so no trimming or anything.
