E61 530d -04, power loss and problems with doors
Old 09-21-2021, 05:13 AM
tonnizi's Avatar
My Ride: E61 530d -04
Engine: M57D30
Originally Posted by donpb
Get that done first. Your battery could be done for, new or not. I had a bad brand new battery before. Just keep an eye on it if it still holds a charge afterward.
That's what I thought I would do. On Friday, I will even put information here if it helped or didn't help.
Old 09-26-2021, 06:19 AM
tonnizi's Avatar
Engine: M57D30
I went there on Friday to check / replace the battery cable in the Campaign.
Everything was okay to hear.
We are still on the verge of the same problem, ie after standing for 4 hours, the power has disappeared from the car.
For testing, I disabled:
MPM Module (No effect)
Driver and co-driver bench modules (No effect)
Trailer Module (No effect)
Now I removed the Radio / Antenna module from under the Tailgate
Old 09-26-2021, 11:19 AM
donpb's Avatar
My Ride: '06 530i N52
Please follow Is My Battery Bad? - 5Series.net - Forums.
Old 09-26-2021, 02:11 PM
tonnizi's Avatar
Engine: M57D30
i don't think it joins me.
because:
- IBS has been removed (no effect)
- Has been tested with my dad's e61 530d battery and during power up the power goes out, no problems in my dad's car. just in my car.
- starter / charger taken out for test.
- Module used out under the trunk drawer.
- MPM used out
- trailer model taken off.
These have no effect
Old 09-26-2021, 02:22 PM
donpb's Avatar
What voltage is the battery? What does the charge histogram show? Disconnecting the IBS isn't testing it. Focus on your own car and not your dad's please.
Old 09-27-2021, 09:52 AM
tonnizi's Avatar
Engine: M57D30
the battery voltage was 12.6V when you turned off the car.
Sleeping Voltage 12.4 and full time range from 12.5 to 12-3.
At the point where no other doors open then the Voltage is 4 - 5V.
Also, as a test, I have borrowed another E61 530D battery for a while and do the same with that battery that the power is lost.
But in the car where I borrowed the battery, it doesn't do that.
Now I’ve taken Start away, and the problem just keeps going.
MPM removed and problems persist.
The antenna module is removed and the problems continue.
Can the body module do?
Old 09-27-2021, 10:36 AM
donpb's Avatar
Did you check for parasitic current draw yet? If the charging system and battery checks out good, then that would be the next step.
Old 09-27-2021, 11:36 AM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Just do a parasitic draw test and be done with it. You're going in circles. You know it's loosing power during sleep mode so do the draw test. It's the only way you're going to find your issue.
Old 09-28-2021, 10:18 AM
tonnizi's Avatar
Engine: M57D30
This question:
- Could the ECU or ECU cables do this?
- So the ecu didn't smell in any way returned or weird and everything was inside ok.
But 3-4 pin pin oxidized, the end of the wires was a bit oxidized.
Here's a picture: https://i.imgur.com/KBykwtd.jpg (Surrounded by white)
Old 11-10-2021, 08:41 AM
tonnizi's Avatar
Engine: M57D30
Fault found, instrument panel ate currents overnight.
The instrument cluster also changed that maybe the power consumption problem solved.
But there will still be a k-can line of faults.
The error codes have been read and here are:
https://i.imgur.com/AX1JQmZ.png
Quick Reply: E61 530d -04, power loss and problems with doors
