E61 2006- horn relay
My Ride: E61, m sport nav, heated seats pan sunroof adaptive lights xenons
Hi all do I have a horn relay? If so where can I find it?
Thanks
Thanks
My Ride: BMW 530xiT (E61)
i dont think so. looks like the horns are operated directly from the steering column module.
from WDS:
"Fanfare horns
The fanfare horns serve both as a warning signal and as redundant-system audible anti-theft alarms.
The directly read horn switch signal is sent as a valid status via the steering wheel module and the coil spring conductor to the steering column module (control module steering column control center). The steering column module can control the high-tone and low-tone horns separately. The power consumption for each fanfare (horn) is approx. 5 A."
from WDS:
"Fanfare horns
