Diversity antenna - comfort access and remotes not working
My remotes stopped working. No control access and no keyless start.
I opened up the rear spoiler just to find the diversity antenna corroded due to moisture and water ingress. I have checked all my fuses and all seems fine. I have not tested the wiring to the module yet. a replacement part is 600$ at my local dealership. Does it require to be programmed once installed or is it a plug and play unit? Can I fit an used one if I find it? can this modules be repaired? thanks https://cimg4.ibsrv.net/gimg/5series...3ea047f746.jpg corrosion https://cimg7.ibsrv.net/gimg/5series...69d43bc334.jpg box ! |
Diversity antenna should be plug and play. good luck.
You can get these on eBay for about $125 - the E63 modules are more common and cheaper - the only difference with an E63 module is that it has captive mounting screws instead of nuts - but you can just switch them out with the antenna you've pulled. The E63 part number is 6934485. Good luck.
I just checked on eBay - there's a few active listings for the E63 module for $25 to $75 - you're in luck.
thanks!
replaced and all is good now! |
My antenna went out. Strange no water damage. I have a '08 535xi wagon with comfort access, will this work?
Thanks in advance |
Originally Posted by quattromeister
(Post 1599939)
Thanks in advance |
Tonight tried debugging a few things and didn’t get very far. With INPA I was monitoring the antenna field strength while doing various tests but saw no issues.
All this to say, seems like everything is working as it should. I would assume a bad FBD would show little to no decrease in performance when unplugged. One interesting thing to note is that on FM my radio reception increased when I disconnected a little 2-wire black plug to the right of the FBD. Not sure what that goes to. Reception went from 12/15 to 8/15 repeatedly. I did notice that one of our two keys has vastly better range than the other. Swapping batteries did not transfer the range to the other key. My wife uses that other key normally and she said it usually works ok, sometimes has to take it out of her purse and put on console to start the car. |
Got an antenna amplifier from a 2008 6 series on eBay for $30 and it appears to have fixed all my problems! My other amplifier is date stamped 2015 and looks great, so not sure what failed. This one from 2007 is working great.
I just pulled an antenna from an 04 6 series, and it works in my 09 wagon. Best $8 I've spent
