Diversity Antenna Amplifier
My Ride: BMW E61 525i 2004
Hello everyone,
The problem:
- the key fob on my E61 525i 2004 is not working
- the language keeps resetting to German
What I have already checked/fixed without any success:
- changed the wiring harness on the right
- checked all the related fuses, all of them are OK
- opened the antenna amplifier, no signs of water damage, but still cleaned it with isopropanol
- checked the keyfob battery with a multimeter, it shows 3.11 V which is OK
What do you guys think is causing this?
I have doubts about the diversity antenna amplifier, even though there is no sign of water damage and the FM radio is working fine. How can I check if it really is the diversity antenna amplifier which is not working before buying a new one (the new one is not returnable)?
P.S: I tried placing the key fob right above the diversity antenna amplifier and pressed the open and lock keys on the key fob, but still does not work.
Looking forward to answers. Thanks in advance.
The problem:
My Ride: E61 523i
Hello everyone,
The problem:
The problem:
My advice to you is to get it replaced even though there isn't water damage it just might be a faulty unit.
All the best
Sheikh
Hello Katitu,
Thanks for the reply. I ordered a new diversity antenna amplifier today. Hopefully that fixes the problem. I will keep you all posted.
By the way, anyone have any idea why the car language keeps resetting back to German from English everytime I start the car? I wonder if this has to do with the diversity amplifier not working correctly, because both the problems occurred at the same time.
/ASZ
/ASZ
Hello again everyone,
So today I received the new Diversity Antenna Amplifier and installed it, and guess what? The key fob started working again! Such a relief.
Although the RADIO worked correctly and there were no signs of corrosion in the diversity antenna amplifier, the fault was still in the diversity antenna amplifier.
This also fixed the language reset problem, dunno how, but maybe someone with more in depth knowledge can explain that.
Thanks again Katitu for the reply.
My Ride: E61 523i
Glad to know that I could help and it has solve the issue, at least you don't have to worry now.
Enjoy
Katitu
JHR-5
05-13-2015 05:28 AM
