Cold Weather package retrofit
My Ride: 08 535xiT
I know I can't put in the heated seats, but are there any other options that I can add?
It's pretty damn cold in MN right now and heated mirrors and heated washer nozzles would be really nice to have. I have already had mine freeze while out driving around for a while.
Anyone know what can be added on?
My Ride: 08 535xiT
Yeah, that might have been helpful, wouldn't it?
I have an 08 E61, the mirrors haven't had an issue yet, but the washers have. So far it is staying in the low single digits for highs, I'm guessing that with windchill it would be well below zero.
The fluid in there is whatever the dealer put in, I can't imagine that they would dilute it.
My Ride: 2007 E61 M5, 1989 Z1
Windchill is only for animate objects and how cold they feel. Given the penny pinching that happens at many dealers I wouldn't be surprised if there's a summer screenwash fluid in your car.
As far as the heated seats see https://5series.net/forums/topic/657..._1#entry725614
If you wanted to be sure, go to any discount store and buy a container of undiluted (concentrate), dump it in and top off with distilled water. (FYI Distilled water is less likely to leave spots behind than the stuff that comes straight from the tap.) Or, buy a gallon jug of the premix stuff and top off.
I personally like the BMW stuff better - it smells nice ;-)
A final suggestion
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
![Clap](https://5series.net/forums/images/smilies/imported/clap.gif)
Check out this site for adding seat heat...it is not as bad as you think...Not OEM, but will should work well for you
http://www.heatedseatkits.com/index.html
