Climate control problem
Old Sep 26, 2017 | 11:51 PM
Rainers228's Avatar
My Ride: BMW e61
Default Climate control problem
I have a problem with my Climate Control Unit. Yesterday went for a drive, started it up, noticed that it doesnt blow air, the control unit does work, it lights up, can turn a/c on and off, but it didnt blow air. So I went for a drive anyways and after some time of driving it suddenly starts working. Went to few places where I had to turn car off and leave, came back and it worked fine. Today after a night of sleep it doesnt work again.
Has anyone had any issue with it?
Old Sep 27, 2017 | 04:04 AM
pocholin's Avatar
My Ride: 2010, E61, 535i xDrive
Model Year: 2010
I did but I also had an ugly noise coming from the blower. Dealer replaced the blower under the extended warranty (2 years ago). Hope this helps.
Old Sep 27, 2017 | 04:14 AM
Rainers228's Avatar
My Ride: BMW e61
I have no noise, except from when i turn on the a/c, i guess it’s trying to blow the cold air. I have no warranty as it’s imported car, second hand, not bought from dealer.
Old Sep 29, 2017 | 05:17 AM
pocholin's Avatar
Model Year: 2010
You might start with the blower, it is behind the glove box, inside the cabin. I don't think it is that hard to change, I only took it to the dealer because I still had warranty, otherwise I would've done it myself.
Old Sep 29, 2017 | 06:43 AM
Rainers228's Avatar
My Ride: BMW e61
Is it behind glove box? I Have 2007 e61. I thought it’s behind climate control and radio and the disk changer
Old Sep 29, 2017 | 12:01 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
It is definitely not behind the glovebox. And while you're at it I would change the whole assembly with the final stage regulator which is probably the issue. There is a lot to take apart to get to it. So change everything. I've done it and it is not bad but give yourself a few hours to do it
Old Sep 29, 2017 | 12:05 PM
blower motor instructions
Old Sep 29, 2017 | 12:17 PM
Rainers228's Avatar
My Ride: BMW e61
Thank you all for your suggestions, I will try anyday soon to change it!
Old Oct 2, 2017 | 11:34 AM
pocholin's Avatar
Model Year: 2010
Sorry, it is behind the Radio and A/C controls...not behind the glove box. It was behind something
