Brake Squeal
My Ride: E61 520D Auto
Hi all
changed my brake pads a few weeks ago and have had major squeal since
thought it might bed in and stop
i know that people put some copper anti squeal grease on them somewhere when fitting
can anyone tell me where I should put the copper grease to eliminate the squeal as I don’t know where it should go
thanks in advance
thanks in advance
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Put it on all metal clips and bracket and and the back of the brakes. Anywhere the brake touch. If you don't cover everything it will squeal. I don't use anti seize but some do. I use CRC brake quiet because it forms a rubber barrier. I put it on let it dry then put the brakes on. You have to clean it with a wire brush every change to get the old stuff off but it last longer than liquid due to dust and dirt.
It took me years to figure that out.
Pauls E61 (02-29-2020)
Hi
i used Eicher from Euro Car Parts
probably one of the economy brands
Greased the parts as recommended by seanjordan and it’s cured the problem so its going good
in terms of brake performance they seem perfectly adequate for stopping so it’s a thumbs up from me
My only issue is how to clear the “replace brake pads” warning that I can’t seem to reset and displayed on the centre console
if I could clear that I would be happy
Thanks seanjordan for your advice
cheers
cheers
Model Year: 05 530i
Engine: 3.0 M54
Anytime. I just know it took me a few brake jobs to figure it out.
You have to replace the brake sensors (1front and 1 rear). They can not be reused. Once you replace them it will reset by itself. They should of came with the brakes if not suggested.
Thanks
no it didn’t come with the pads
maybe that’s why they are economy and nearly 50% of the other leading brands
lesson learnt there
thanks for the info
much appreciated
lesson learnt there
thanks for the info
much appreciated
NavarroOne
DIY: Do It Yourself
01-25-2012 06:23 AM
