AWD DSC ABS etc etc. shutdown? 2010 535xi E61
My Ride: 2010 535xi Sportwagon
Persistent 005E5C and 005DEC errors. (Left wheel speed sensors incorrect or shorted)
Replaced the sensors, they hit the rusty bits on the CV axle shafts.
Replaced the CV axle shafts and sensors, no joy.
The steering angle sensor error just started, I reset but, keeps coming back
Thinking aboiut lighting it on fire in a ditch.
Learning more German slang as we go along
Fotze!
Fotze!
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Did you replace it with an OE, OEM or aftermarket sensor. If aftermarket then you are going to go around in circles. All sensors need to be at least OEM. Also make sure your shaft has the abs ring and you cleaned all the rust. If these are fixed then your codes will go away.
After market everything...
The front shafts have rings - my left was so badly rusted it was grinding the face off the sensor.
The rear is something different? Not a ring but, a bumpy surface?
I replaced the left side cv axle shafts and both sensors and no change
No ABS DSC AWD this thing is going to be useless when it snows.
I guess we may be calling it quits soon?
Left front and rear...
They are the malfunction and the only side I have looked at, oddly the steering angle sensor just started as well?
I DUNNO!
I DUNNO!
