Auto tailgate hydraulic fluid top up?
Old 05-25-2013 | 12:01 AM
Steve Judd's Avatar
Default Auto tailgate hydraulic fluid top up?
So, if you look at the pic my question should be obvious..
This is from a 2006 e61, with an auto tailgate that only goes half way up, and as you can see the Hydraulic fluid is low.
Shellair 4 seems to be the required fluid, BUT, I cant find a schematic anywhere on where to top it up from?
Anyone?
Attached Thumbnails Auto tailgate hydraulic fluid top up?-20130525_160756.jpg
Old 05-25-2013 | 05:42 AM
constant's Avatar
No idea, but if you cannot get an approved method you could always brute force a fix. It looks like they used a crimp clamp for the reservoir in typical BMW style. Maybe it's possible to cut the clamp, top it off, and replace with a regular worm style clamp?
Old 05-25-2013 | 01:37 PM
Laco19's Avatar
You have to remove the entire pump assembly (2x M6 nuts and 1x M6 screw) and turn it upside down. The filler hole is on the bottom of the reservoir. See picture below:
Old 08-14-2013 | 11:17 PM
huntington's Avatar
My Ride: 2003 BMW 325i 2008 BMW 535xi Touring 2005 Lexus GX470 2000 Audi A4 1.8T
Good to know!
I'm having the same problem where the lift gate stops half way up or down.
Headed in for service tomorrow.
Old 09-04-2013 | 10:50 AM
paulie's Avatar
My Ride: E61 525i 2005, F11 528i 2012
Model Year: 2012
I have the same problem. I was wondering what kind of work the dealer did? Is it easy to do yourself?
Old 09-07-2013 | 12:40 PM
awt's Avatar
awt
My Ride: 2001 320Ci Coupè
I've done this myself, easy job.
Old 10-13-2013 | 05:34 AM
fivethirty's Avatar
My Ride: 2006/7 530d M spec touring, fully loaded
How on the planet do u turn the pump upside down? I can't move it further than 90 degree angle, no way of topping up, e61 2007. Pix anyone??. please
Old 10-13-2013 | 09:44 AM
Laco19's Avatar
I have no picture, see service manual:
File Type: pdf
Old 12-12-2013 | 11:17 PM
lamaja's Avatar
My Ride: BMW 530 xd
I have 2006 530xd equipped prologic i7 sound system. There is an amplifier for the system where the pump must be. Where could I find it? Anyone? Thanks.
Old 12-13-2013 | 01:31 PM
awt's Avatar
awt
It's behind the amp.
