Auto shifter problem.
1 Attachment(s)
I've encountered a problem where my shifter 'lags'. When I want to put it in drive from Parking, it takes about 4 seconds, sometimes it even doesn't puts it in Drive. I've been to a mechanic, he says the problem is that the car doesn't recognize the shifter, like it's not even there. He said he will call someone up and gather some info about, he hasn't called yet, but I wanted to ask for your advice. Maybe some of you have encountered with problem like me? I have bmw e61 2007.08. model.
I have shifter like this (taken from different post on this website): Attachment 165339 |
That's the sports shifter.. so if your car did not come with it, it's very likely whomever coded it.. didn't do it at all, or didn't do it right.
Originally Posted by rice_rocket88
(Post 1584689)
If you could, take a picture of what you have specifically.
Originally Posted by stormhammer
(Post 1584804)
Well, that shifter you posted is an LCI model + the sport button, which E61's didn't come with from the factory ( well, I'm unsure if they did over in Europe )
IMG_2522.jpg Photo by pootang | Photobucket the left is pre-LCI ( 08 and earlier ) and right is LCI Nice thing is, these are all digital, so if you can find a used one ( shifter assembly ) it's virtually a plug'n'play. The concern comes in if someone did coding like mentioned before. |
(Post 1584812)
Your build date should be LCI so the shifter should not have any compatibility issues. Regardless of coding, the shifter is plug n play. Coding/flashing is necessary only to get the sport button working and enable paddle shifters. I installed mine and used it long before flashing and coding.
Does your Sport button work? Do you have paddles in the car? Have you checked wiring within the console to confirm a good connection? Has your mechanic recorded CANBUS communication when he attempts to actuate the shifter? |
Originally Posted by GTYellowJacket
(Post 1584830)
