Another Project Wagon
Synced up with a local enthusiast who was parting out a few E60 M5s. I was able to get everything for the black interior conversion minus the door cards, seat backs, and lower seat trim. I also picked up a front/lower M5 splash shield in good condition.
I put all the small plastic trim pieces in the washing machine and after a quick cycle used some interior conditioner and a microfiber towel to clean/dry/condition and they look excellent, better than expected to be honest.
M5 carpet and splash shield
Center console
Downloaded the XHP Trans Tune Package (Stage 1, 2, 3) and flashed Stage 3 to give it a whirl, it sounds promising as it makes the trans 50-60% more responsive with some other benefits. I need to let adaptations relearn the new tune for ~50 miles before giving it the beans but excited to see the improvements.
Overkill for this TCU flashing but it's nice to know I could completely rewrite/flash a BMW overnight with the modules being help at a perfect 14.2v One badass charger.
I also snagged a lightly used M-sport SSG steering wheel from a 2010 550i w/ 19,000 miles and it looks to be one with Nappa leather so it's essentially an M5 wheel without the tri-color stitching and SSG push/pull paddles as opposed to the SMG pull/pull. I prefer the pull/pull style but the SSG does have 2 benefits: 1: You can drive and shift with one hand 2: If my research is correct retrofitting this only requires running 2 wires from the wheel, 1 to the DME and 1 ground, and some coding to integrate the wheel. XHP claims "instantaneous" paddle response, looking forward to that.
Here is a pic from the eBay listing, little dirty but should clean up nicely.
Center console
My Ride: e61 / KW V3 / JB4 / M5 Rear Sway / FDL Coded / SAT Retrofit w GKE flash / ER FMIC / BMS DCI
Model Year: 2010
Engine: N54
You just need to run the following:
- SZL Connector x1880 Pin 13 to Connector X6031 Pin 11 in the ECU enclosure (which runs the rest of the way to the transmission control)
- SZL Connector x1880 Pin 12 to any good ground.
I could never find the exact BMW part number for the connector terminals, so after a lot of scouring datasheets, I bought the following TE terminal contacts from Mouser:
- 963715-1 (or -5, -6 for different plating, depending on availability)
- 1452656-1 (or -2, -3 for different plating, depending on availability)
These clicked right into the existing BMW connector bodies in the wiring harness. You'll notice that the mating male pin in connector X6031 is a little wider than the pin in X1880, so that's why two different contact PN's were used.
To complete the clean mod, you can integrate the new wire into the existing wiring harness down the steering column and across the dash over to behind the glove box. From there, it can be fed directly into an existing opening in the ECU enclosure and cleanly routed to connector X6031.
And after that, just one line of coding to make the paddles "Aktiv"! If for some reason you have any trouble after coding, SIB 25 03 07 provides diagnostic procedures for checking for the right voltages at Pin 11 of X6031.
I'll be interested to hear if the XHP firmware truly makes the paddle shifts instantaneous. Although having the paddles is better than the stock shifter alone, they're definitely not any faster, even with the full SAT retrofit.
My Ride: 2008 535xI Wagon
Engine: N54
what are the differences between the M5 subframe and all others? it seems the M5 subframe has a different part number than all the others, according to RealOEM. i ask, because there is a guy local that is parting an M5. and i'd like to just grab the whole front setup from him, vs. piecing it together from the junkyard and eBay.
We will see how "instantaneous" the paddles are, it's a bold claim.
can you elaborate on this a bit more?
Nice weekend for the wagon.
- Cleaned and swapped most black interior pieces (need console, seat trim, and door cards)
- Ran wiring for paddle shifters
- Cleaned and installed nappa leather M sport wheel
- Installed Depo smoked side markers
- Replaced faulty TPMS module
- Installed new OEM roundels
- cleaned and conditioned leather seats
- installed new Bosch spark plugs
- Replaced driver seat belt
- repaired driver door weather stripping
- targeted valves which need cleaning and expansion tank which needs replacing
Stock side marker
You can see the driver seat belt was missing the plastic nub which keeps the buckle from sliding all the way down, it was pretty annoying to reach all the way down to your left hip for the buckle. Seat belt was replaced.
Had some left over wiring and pins from my manual swap on the white E61 so I built the wiring needed for my paddle shift retrofit
One wire to ground and the other to DME box, easy peasy
So much room for activities!
Before
During
After
With the seats out I took the opportunity to clean them. Horse hair brush, leather cleaner, micro fiber towel, leather conditioner
Weather stripping had worked loose
Repaired using the ever so awesome 3M VHB tape
Found a Nappa leather SSG M sport wheel on eBay from a 550i with 19,000 miles, shown left.
Cleaned up the leather, swapped over the old lower trim (not a fan of M badges) and transferred the buttons
Stock side marker
Before
During
After
My god man, that wheel is a thing of beauty. I love that you de-"M"'d it. Looks so much more stealthy.
Been following your progress with this one and learning a bunch, I really appreciate you taking the time to do these posts. These are really wonderful cars in the right hands.
I would actually love your help tracking down one of those M5 wheels, and helping me out with the swap on my E61 if you have come across another one. (Happy to pay you for your time.) I am in Orange County, I think you are as well. Sam Williamson with SpeedLogic has been helping me with sorting out the mechanicals on my recently acquired E61.
I used to be in Orange County but have since moved to San Diego. Sam is a good guy we have hung out a few times. As for the steering wheel there are 2 options the M5 SMG wheel with pull/pull paddles and the SSG push/pull wheel (like I got) from M sport E60 models. I would look for a wheel from a 2008+ E60 whichever style wheel you prefer. Personally I like the M5/M sport models with the Nappa leather as it feels considerably more luxurious (IMO). Most M sports don't have Nappa, some do, some M5s do, some don't, just something to consider. E63 M6 wheels will also work if you find one of those. The retrofitting process is pretty simple, you will need some of the small connector pins which can be a pain to obtain but once you have them you simply connect 2 wires into a connector on the steering column, runs one to the ground under the carpet and dead pedal, and the other goes to a connector in the DME box in the engine bay. After that there is some basic coding needed to activate the feature. That's it. I can forward you a guide I received from another member and I am sure this is something Sam can assist with.
Evan
My E61 was missing those seat belt stops (those little buttons that keep the latch from falling to the floor) so I just bought a pack of 10 on Amazon because it was cheaper than buying 2. If you or anyone else ever need any let me know and I'll throw some in an envelope! They just snap on with some pliers.
My Ride: No BMW
Wow! You've been busy! Nice work on the pin/solder/wiring work. Did some of that kind of work at Roush. Definitely understand the pain of having to search out pins for the proper connectors as I was integrating bluetooth into the aux of the CCC unit in my last E60. That black carpet looks much better in there also.
Mechanic hack, release hood struts to open the hood 90 degrees for better lighting and access.
Took a peak at the valves and they will need to be walnut blasted
New bosch plugs
Expansion tank also looks to be nice and toasty, there are some stress cracks and discoloration so I ordered a new one.
New OEM roundels and RDC (TPMS) module to replace the faulty one.
For those who got unreasonably upset that I plasti-dipped the old UV damaged roundels, you can now relax and go find something else to stress over
New bosch plugs
