Alarm issue
Alarm issue
My remote locking is not working after checking and replacing the rear wiring around the boot, I have checked the diversity antenna and it looks fresh, undamaged or corroded.
Could it be a fuse issue?
I am using the emergency key at the moment until we can figure it out however each time I use the key to unlock the car the alarm is set off until I get the fob in the ignition.
Is there anything I can do to prevent this ?
Thanks for any advice in advance
My Ride: F11 -14
Hm.I think you need to check if there is a signal from the antenna first, just to make sure it isn't the culprit - the issue with the antenna is a fairly common one I'm afraid.
Thanks for that information, this may be a foolish question but how do I check? As far as I can tell using the key it's dead.
Is there a fuse I can remove for the alarm in the mean time?
pigment
09-15-2019 11:34 AM
incoherent
04-15-2015 04:48 PM
