9caa error code terminal 30b
My Ride: Bmw e61 520d se (poverty spec) DPF delete Egr delete swirl flap delete with map to support,
E61 2007 lCI 530D
I've tried the search function with no luck but hoping someone can shed some light.
I've got the above error code when scanning via the old port 9CAA TERMINAL 30B CONNECTION FAULTY.
Has anyone had this code and solved the issue
Engine: 3.0 B58; 3.0 M54
Usually that means a fuse is blown. I think 40a but don't remember the location of the fuse. It has to do with the gateway
