2010 535i e61 help
Old 07-16-2023 | 08:09 PM
Be612569's Avatar
My Ride: 2010 BMW 535i Xdrive e61 LCI
Default 2010 535i e61 help
I have been getting intermittent 30FF and 30FC codes. Odometer currently is at 159,000 miles. I noticed the car seems to lag and shifts hard sometimes especially going into 3rd gear. It is an automatic. I have done the transmission service less than 2 years ago. Would it be the wastegates going bad or the turbos are about to give out? Or maybe I need to run a smoke test and start from there first?
Old 07-16-2023 | 10:55 PM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I would look to see if your diverter valves are clogged then troubleshoot from there.
Old 07-17-2023 | 05:51 AM
Drifter2090's Avatar
My Ride: E61 535xi - F87 M2 - E36 328ic - E92 M3
Model Year: 2010
Engine: N54
Running into the same codes on my 2010 535xi touring 187k miles, only get it after WOT for a long time. Will be replacing all my vacuum lines with new silicone and doing a aftermarket charge pipe and BOV.
Old 07-17-2023 | 03:56 PM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2001 325i 5MT
Engine: N54, M54
When my turbo wastegates were failing I would get a 30ff code at 2,500 rpm with a lot of throttle demand. Is your situation similar?
Old 07-21-2023 | 08:39 AM
Seth dustin's Avatar
Banned
My Ride: Looking for a car
Originally Posted by Be612569
I have been getting intermittent 30FF and 30FC codes. Odometer currently Tutuapp 9Apps Showbox is at 159,000 miles. I noticed the car seems to lag and shifts hard sometimes especially going into 3rd gear. It is an automatic. I have done the transmission service less than 2 years ago. Would it be the wastegates going bad or the turbos are about to give out? Or maybe I need to run a smoke test and start from there first?
The fault code 30FF is often associated with wastegate-related problems. Wastegates control the amount of exhaust gas flowing into the turbocharger, regulating its speed and preventing over-boost. If the wastegates are malfunctioning or sticking, it can lead to poor turbocharger performance and affect the engine's power and response.
Be612569 (07-22-2023)
Be612569
12-13-2022 06:15 PM
Toronto5.5
10-14-2020 12:29 PM
antonrus
08-27-2014 07:26 AM
blademan
03-19-2013 12:23 AM
Hopco
05-28-2009 03:05 PM
Quick Reply: 2010 535i e61 help
