2005 E61 - instrument panel not working entirely
Hi all,
Firstly, this is my first post on this forum so I guess I should say hello! I am very fortunate to have 2005 530d M Sport Touring in the UK (space grey). It has only done 34,000 miles so is in excellent condition . I have owned it for nearly two years and it has been very reliable and is like driving a new car every day!
Here lies my problem:-
I noticed today that the lights on my dash board for the side lights and the dipped beam headlights have stopped working. The actual lights they represent work fine. I have checked the fuses and there doesn't seem to be a problem. Although the car is 7 years old it has only done 34k miles so it very clean and well looked after, I am therefore at a loss as to what the problem is. If I flash full beam or use the fog lights the dash lights for these work fine. All the other self check lights (eg Airbags ABS) work fine.
I was wondering if anyone on here has had the issue but more importantly successfully had it rectified?
Thank you for your kind consideration.
Daniel
Daniel
Hi Daniel, I was not aware that there was an indication lamp for the headlights on the main cluster (except high beam assist). I have an lci and the only indication for the headlights is a small green led next to the physical headlight rotary switch.
In the hidden OBC menu 2.01 you can perform a cluster test and see what lights up.
I am sure there is a green dipped headlight symbol - I'm just off to google that hidden menu to see if I can attempt a cluster test.
Thanks a lot for taking the time to respond.
Daniel
How stupid do I feel!!! I don't have them!!! A BIG THANK YOU TO XD-BLUE - Just imagine the embarrassment and cost if I had indeed taken it to a Main dealer!
In my defence, I live at my work so last drove the car a whole week ago but have been driving my wife's Skoda to fill it up with petrol - I have just checked hers and she has the green dipped light bulb in the dash cluster.
Thank you very much.
Daniel
TexaZ3
05-06-2015 09:54 AM
