18" Rims an ET´s
Old 07-07-2012, 06:27 AM
zola's Avatar
Hi guy's,
Some days ago I bought 4 Alloy Wheels 18" 8" BMW 135M of friend of mine. The ET is 47 from a 3 series but I need to know if I can use it one my 5 touring E61 and the modification in need to take.
I need spacers? and the size of spacers? Can you help me?
Tinking in tyres 235/40/18. Opinion?
Old 07-07-2012, 06:29 AM
zola's Avatar
I forgot to tell . Is a 07' 520d touring
Old 07-17-2012, 09:28 PM
colb666's Avatar
My Ride: E91 sport + touring
To fit these you will need spacers of around 30-35mm and I'd reckon on a 245x40x18 tyre size
Old 07-22-2012, 09:18 AM
crewzer's Avatar
All wheel drive, or just rear wheel drive? The ET's are different...
Assuming your 520d is rear wheel drive, the factory ET spec is 20mm, so you'll need spacers of ~27mm. You'll also need longer wheel bolts.
245/40R18 looks like a good tire size.
More information.
Regards,
Jim / crewzer
Old 07-23-2012, 03:05 AM
crewzer's Avatar
More info: You're probably looking for something like this.
HTH,
Jim / crewzer
Old 08-05-2012, 06:01 AM
zola's Avatar
Some friends are against the use of Spacers. What do you think abou the use of that 30mm Spacers?? Any problems in the future? Maybe the best option are try to change to another wheels with correct ET. ?
Bye
Old 08-05-2012, 07:57 AM
luigi524td's Avatar
Bye
+1 ...
Old 08-05-2012, 10:26 AM
norsecarnut's Avatar
My Ride: 2008 535xiT6
Absolutely. Especially when you are fine with using 18" wheels, plenty of people sell 18's because they want to show off with a larger looking wheel. Therefor you can find 18" for very affordable cost.
Tire size, 245/40x18 is factory standard. The 235 will be too small. In fact you can easily use a slightly larger tire like 245/45x18, but smaller than factory spec would not be a good idea.
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
bestofthebest
10-02-2015 03:21 PM
bimmerspeed
09-23-2015 03:50 PM
Domrepkid
09-23-2015 01:44 PM
Quick Reply: 18" Rims an ET´s
