What part number for rear window trim
What is the difference between these two parts?
51317027916 51317057415 Need to order for 08 550i but trying to find out the difference and want to avoid ordering wrong part. https://s15.postimg.cc/6ru819c7b/rwc1.png |
Have you checked realoem.com with your VIN #?
Re
Originally Posted by JayArras
(Post 1595758)
So far I had no luck in finding out the difference therefore I'm stuck as might end up ordering a wrong part. |
Who are you ordering from? They should be able to help you make the right choice or accept the return if they advise you incorrectly.
Re
(Post 1595783)
The other part number is for climate comfort vehicles, I guess this was not an option in US. |
You can use the VIN decoder to see if any of the options (S106A,S356A,S357A) listed for the other part number is applicable for your VIN. You are probbably correct with 51317057415.
Hello, I just replaced my window trim on my 2008 535i Monday. And I can say that the part number 51317027916 is the part you're looking for. (If you're looking to replace the rear window molding.
here's the exact link from Amazon: Genuine Rear Upper Windshield Molding Seal Trim BMW 5 Series E60 M5 2003-2010 https://www.amazon.com/dp/B00BH2YW7C/ref=cm_sw_r_cp_apa_kjhsBb4K270T8 |
Forgot to update, replaced rear window trim last week, confirming correct part number 51317027916.
