Tips for exhaust stall coming up
So I went with RPI and when it comes I will hopefully do my own install. I have installed two other exhausts before, however RPI uses a pipe that goes much further back. Problem for me is I do not have access to a lift and the other two I literally slid myself under the car and could do it.
However I never had to cut my exhaust since that was done by the very first install which was a pro-
1.What tool do you use to cut your exhaust pipe
2.Rubber hangers-I had the hardest times both times getting the metal hanger out of the rubber hanger-mine are new and tight too and can someone show me a tool that works for this. I had to end up literally cutting one off to get the hanger out.
Obviously this is all much harder on your back laying under the car. But for 200 bucks Ill do my best.
Second-would this be safe to do with your car on jack stands in the rear or too much movement with exhaust going on and off?
My Ride: 2006 550i, Premium Package, Navigation, Comfort Access, L7 Sound
2004 FX35, Sports Package, Stillen CAI
Get plenty of blades....went through quite a few to cut my pipe off.
My Ride: 2005 525i, 6spd manual, Premium pkg, Cold Weather pkg
Originally Posted by darkboyz68' post='1004284' date='Sep 10 2009, 06:55 PM
Hello Diamond, i thought RPi's exhaust are straight bolt-on?
Why do you need to cut the pipe?
Did you buy an RPi exhaust designed for another 5er?
My Ride: A Car faster than yours.....
The stock 5 series exhausts are one piece so if you are installing an axleback, youll have to cut. Only the M5 full systems are direct bolt ons (for e60).
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
Then lift the exhaust so that the hanger is not tensioned and prise off with a screwdriver.It's always worked for me.
stillak
04-22-2015 04:30 PM
