Style 124's FTM --> TPMS ???
Old 01-23-2010, 02:36 AM
medik13's Avatar
I found a set of 124's that came off of a 2005. He has the FTM sensors. However, I have the TPMS sensors. Are they TPMS compatible?
Old 01-23-2010, 03:02 AM
god_003's Avatar
My Ride: e60
his car has ftm
the wheels dont
ull have to place the senors into ur car in order for it to read them correctly
:l
Old 01-23-2010, 05:37 AM
medik13's Avatar
Can I just add the TPM sensors to the wheels?
Old 01-23-2010, 11:44 AM
medik13's Avatar
Please help. I am about to buy these wheels but need to know if I can just add my old TPM sensors to the wheels. Will they fit and work properly?
Old 01-23-2010, 11:46 AM
Gene's Avatar
yes...they should fit properly/transferable....I did the same thing when I went from 124's to 166's...
Old 01-23-2010, 12:32 PM
god_003's Avatar
My Ride: e60
yes u can
the tpms sensor is a specialized valve stem and radio transmitter
they can be taken in and out and exchanged between oem and custom wheels
ftm... what his car has (not his wheels)
is a different tire pressure sensing technology that deals with abs and gives u no real data in ur car
ie. tire pressure
Old 01-23-2010, 01:32 PM
medik13's Avatar
Thank you...I was just worried they wouldn't fit into the holes.
Old 01-23-2010, 02:22 PM
luigi524td's Avatar
Thumbs down
The TPMS will fit fine but if the gasket set is worn there is a "repair kit" that you can buy at the stealer for less than $10 to repair where the stem and xmiter join and pass through the tire. There are probably aftermarket kits that will work too.
A word of advice, the gaskets, xmiter and stem have to be assembled correctly on the wheel or the stem will leak! An experienced tire installer has to know what he/she's doing. This is a little different than pulling a rubber tire valve through the hole on a wheel! Ask me how I know
Old 01-23-2010, 02:57 PM
god_003's Avatar
My Ride: e60
they r easier than u think
:l
the removing of the tire and placing of the tire onto the wheel is where the technical part comes in
someone not aware of sensors in a wheel can crack the housing making them inoperable
but the actually removal of the sensor u dont even really have to remove the tire
just press on its sidewall untill the sensor is reviled and with a socket and ratchet, undo it
if the value is seemingly stuck in there...
give it a lil tap with the ratchet, careful not to hit ur wheel or let it fall into the tire (then ull have to remove it)
i doubt u will be doing all this
just fyi
Trinity Autosport
09-22-2016 11:08 PM
bestofthebest
10-02-2015 03:21 PM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
Tsubasaftl
09-12-2015 01:34 AM
Quick Reply: Style 124's FTM --> TPMS ???
