Sportautomatic (SAT) retrofit
#871
My Ride: E60 560X
You never describe which paddles your going with (DCT or SSG???) They are different! If im going to guess your doing this install on 8speed trasmission (which you also not indicated, whats wrong with you dude?)
By guessing and kinda knowing that if shifter goes back to D it means coding is wrong, so your best bet is to leave it in Wert_00 where its happy, you should look into one of the 3 main areas: resistors at paddles, your ground or both of the wires has to be going from paddles to mechanics! <THIS SENTENCE is very confusing but true since I don't know your full setup!
P.S Error in EGS 5087 "EGS: Hardware, inputs, one touch function" when paddles coded to wert 01 or wert 02.
#873
My Ride: 530e Alpine White
Model Year: 2017
Hello, sorry for bumping such an old thread, but I have problem. Car is a E60 525D LCI NX51, I try to install steering wheel with paddles which I've done before on 530xd and works like charm. BUT here is my problem: I updated EGS before starting with SP Daten v66. I ran the wires from the SZL to ground and to the connector in the Ebox, removed $205 from VO and added $2TB, coded kombi and EGS and the result is: When I press the GWS to D/S it returns itself to D and paddles not working neither on D or on D/S. Tried many combinations paddles wert00 to paddles wert02, tried updating the GWS and killed it, so got another one and the same thing. GWS returns to D when pushed to D/S and paddles not working. Can anyone confirm if its possible at all to get the paddles working on 525d lci? Or the problem is in me somewhere? Thanks.
P.S. When paddles set to wert00 in EGS the GWS does not return to D itself, but the paddles are not working either.
#874
My Ride: 2008 535xi Touring
WinKFP failed
OK, realize this is an old thread but hoping someone has the knowledge to get me out of a jam.
I tried applying this mod and got an error in WinKFP (error 211)
I've tried searching this error and the few posts I've found are unrelated or don't have details on the fix. I was able to update the DME ECU without issue, but EGS fails with the same error. I've checked my settings and tried changing the config of WinKFP to no avail. Hoping someone can help as I can now only turn on the engine - EGS doesn't seem to be recognized and I don't get any lights (PRND etc) on the selector and nothing on the cluster.
Here is my identification from INPA (from an old screenshot):
Any help is appreciated.
#875
My Ride: e61 / KW V3 / JB4 / M5 Rear Sway / FDL Coded / SAT Retrofit w GKE flash / ER FMIC / BMS DCI
Model Year: 2010
Engine: N54
PM your email address and I’ll send you any of the documentation I created back when I did this a few years ago.
#876
I don’t recall getting the same error, but my first attempt failed, and I got the same symptoms of a missing transmission. I had to use WinKFP in some sort of expert mode, manually setting up everything, and program directly to the EGS address. On the second try, I also put on a much stronger power supply and turned off all vehicle electronics, and it worked.
I appreciate the reply. I reached out to BimmerGeeks and they directed me to Bimmer ECU solutions. I worked with Levan and he tried to remotely resolve the failed flash but was unsuccessful. He mentioned that it looked like I did the right process (in Expert mode in WinKFP) and I probably had a bad cable or some other issue. I tried two separate cables, so who knows?
(he refunded my money and I thanked him for his time - highly recommend his services, fast, courteous and professional)
In the end I ended up having it towed to my local independent (Bavarian Performance Group) in Woburn, MA and they were able to resolve it with ISTA/P. (Also highly recommend their services). In the end I was only out the cost of a software update (which they also performed).
It it sounds like I should probably just use XHP, MHD and ProTool and leave the factory software to pros.
#880
My Ride: Bmw e39
@Laco19 You are still here ? I want to retrofit the M5 steering wheel in my non facelift e60 ( 2005) . I don't know what type is my steering wheel with paddles ! I can wire it to work on my car ? Thank you
This is the steering wheel !
Or maybe anyone from here who now how to wire ?
