Sportautomatic (SAT) retrofit
#371
I read an article that the M1 should be changed to S1, when the leveler in the DS mode, but I have not seen it.
This is the most important question that I have to decide.
Who can help in this matter?
Thanks
#372
My Ride: 2008 550i M-sport, retrofitted heated M-sport steering wheel with paddles, Sport-auto transmission
If I recall correctly, in a non-SAT automatic the display just reads "DS" when you move the lever to the left but don't change gears - it doesn't show what gear the car is in. Maybe someone without SAT can confirm?
#373
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights
Planned mods:
Folding mirrors - Modmynav kit - High gloss shadowline trim -
#374
Engine: N54
My self coded SAT module does not show S1-S5.
Anyone that codes with NCS and has factory SAT want to share trace files and I will try and figure out the coding for DIY SAT install.
#375
I have the same problem.
Also, I do not feel the difference when sport button is pressed.
Who knows how to solve this problem?
#376
My LCI 535d which is non-SAT shows M1-M6 when lever is pushed to the left. M1-M6 won't appear immediately when you push it, it will be DS initially but as soon as your push it forward or back (+ or -) to change gear it will change to show the gear like M4 etc.
#377
If anyone here in Calgary has NCS, I'm willing to be the guinea pig. My SAT is dealer retrofitted with all of the factory parts/coding, including VO change approved by BMW (and warrantied).
#378
#380
read more here :
https://5series.net/forums/topic/110...etrofit-redux/
post #22
