Sportautomatic (SAT) retrofit
#121
My Ride: 2008 550i M-sport, retrofitted heated M-sport steering wheel with paddles, Sport-auto transmission
Will do. Like I said, hopefully it's just a question of communications between the SZL and the trans ctrl unit. The paddles connect separately to the SZL module, so even if they're not connected the trans ctrl unit may still be expecting to be connected to the SZL. I'll ask if the SA can check this while fixing my wiring and let you know.
#123
My Ride: 09' 525i M Sport
Alpine White
19" 172 Alloys
Logic 7
USB
Sun Protection Glass
Lumbar Support
SAT (Sports Auto Transmission)
Are you just doing the hardware swop and are you doing it yourself ?
#124
#125
Now... all that being said we've all seen that SA's are not always correct. When there's no specific information from BMW on a particular issue, they sometimes need to make an educated guess based on their experience... which is where you are at this point. I'd suggest having a talk with your SA about running a wire from the SZL to the trans ctrl unit (I think it actually connects to a fairly accessible junction box) to see if it fixes the issue... this probably would be minimal cost, and just might be the solution. Failing that, I guess your choice is to either de-program the S2TBA option from the car or to complete the retrofit with the addition of the wheel with paddles.
Given that others were able to swap in the SAT shifter box and successfully program the vehicle to accept it - you'd think there has to be a solution to make this work without adding the paddles...
_________________________
2008 550i M-sport
2006 X3 2.5i
#126
2008 550i M-sport
2006 X3 2.5i
#127
My Ride: E61 535d carbon black m-kit panoramaroof with beige nasca interior and wood trim. 172m rims. DimSport Race, SB, SAT
Fantastic follow up, thank you so much. I've decided to have it returned to the stage where I just did the hardware install as I don't have the shift buttons and BMW will oblige with that at no further cost; that's 98% as far as I'm concerned and I want to close this chapter and move on, enjoying the car.
#128
My Ride: 2008 E61 535xiT Black on Black
On the subject of shift paddles, it looks like you can't have it all:
32342283945 M steering wheel (heated and lane departure, NO SHIFT PADDLES)
32342283952 M steering wheel (NOT HEATED, lane dep, shift paddles)
32342283949 M steering wheel (heated, NO LANE DEPARTURE WARNING, shift paddles)
I guess if I HAVE to choose, I'll give up the heated steering wheel. I wear gloves in the winter anyway!
#129
There's always the option to go with the plain 'ol sport wheel 32346774125 that supports all three...
#130
Just dropped off my car and had a short discussion with SA regarding the communications from the SZL to the trans ctrl unit. He believes that the fault would still exist even if you connected the SZL to the trans ctrl unit based on the posted SIB, as he thinks the SZL would detect that the paddles were not present and create the fault code. Unfortunately, for the rewiring we're doing today he will not need to get at the SZL on my car so he won't be able to test the theory (although he has surprised me in the past -- if he does manage to test the module disconnecting the paddles I'll let you know). He believes you would need to actually have the paddles in place and connected to the SZL for the fault to disappear.
2008 550i M-sport
2006 X3 2.5i
2008 550i M-sport
2006 X3 2.5i
Alles Beste!
