Sportautomatic (SAT) retrofit
#101
My Ride: E61 535d carbon black m-kit panoramaroof with beige nasca interior and wood trim. 172m rims. DimSport Race, SB, SAT
Without going to the dealer, you get:
- Faster shift times
- Direct steering
- downshifting with intermediate throttle application
By going to the dealer, you get the following addional features:
- when sports button pressed, "SPORT" being displayed on your speedometer
-in DS mode, with sports button pressed, you actually see which gear the car is in
that is all i can think of at the moment..
But guys beware - the dealer will not readily program this for you... You need a "open minded" dealer to this for you. Mine was not willing to do it, though like i said, i found one in germany, but it is a 3000km drive for me
greetings
- Direct steering
greetings
#102
You mean the console from slide 3 of my diy? there is only one that is a combination of black and shiny metallic. See pic:
Attachment 55404
Attachment 55404
Just when installing I was envious; thought my sportsbutton was white plastic and not the neat black with led and "sport" in the button but turned out to be a protective cover that had to be removed... do I feel silly.
Meantime I've seperately asked whether the steering was affected on a normal car without the active steering option - and I can confirm that it is; the steering gets really heavy. I've only gone around the block twice and cannot say I'm particularly impressed with the shifts just yet, compared to DS mode, but I hope a bit of acceleration timing will prove me wrong.
#103
My Ride: 2008 550i M-sport, retrofitted heated M-sport steering wheel with paddles, Sport-auto transmission
Paddle-shift update: Still stumped... paddles don't function and we're having some strange behaviour from the SAT shifter (ie. won't stay in DS or manual mode). We're back to a detailed analysis of the wiring diagrams now that we have the correct version for my 2008, and will hopefully have a go forward plan later this week. With luck we'll have the car back in, re-wired as appropriate, reprogrammed and back on the road soon. If/when we get this working I'll provide whatever detail I can if others want to do this...
_____________________________
2008 550i M-sport
2006 X3 2.5i
1998 528i (retired)
#104
Make sure you try the "manual" shifting also, as one of my favorite improvements from the retrofit is the rev matching on downshifts. Let us know your results from the acceleration timing - my "butt dyno" felt a fairly significant improvement from my old DS mode (and my gas mileage went through the roof in sport mode), but would be curious to see some objective comparisons.
2008 550i M-sport
2006 X3 2.5i
1998 528i (retired)
2008 550i M-sport
2006 X3 2.5i
1998 528i (retired)
Thanks
#105
Shift box/gear selector : 61319204093
Selector lever handle: 61319142950
Sport switch: 61319142869
Trim (leather): 51166960789 (the other two trim options were not available in Canada)
If you want to do the whole paddle-shifter/heated wheel, I will need to let you know in a couple of weeks when we finish the process (Yup! We figured out the wiring issue and I'm booked in at the beginning of May to complete the install!! )
2008 550i M-sport
2006 X3 2.5i
1998 528i (retired)
#106
If you're just doing the shift box/lever:
2008 550i M-sport
2006 X3 2.5i
1998 528i (retired)
2008 550i M-sport
2006 X3 2.5i
1998 528i (retired)
Trim (leather): 51166960789 : should it be Trim (leather): 51166960879 ? (typo?)
Thanks again for your help
#107
For my Danish car (steering wheel on the left side, like in US), I got the following:
? 51166960879 ? Console cover (incl black leather)
? 61319142869 ? Sports button
? 61319208271 ? SAT Shifter (renamed, used to have part number 61319142950)
? 61319165671 ? ECU
? 61319165671 ? ECU
#108
Good catch on the trim typo - it won't seem to let me edit the post though...
#109
Dealer first said he got it right, then he couldn't do it and blamed the install for shutting down everything; even claimed the central control unit was almost blown. took 3 days and to no avail, finally got nothing out of it except that my caravan hitch connection now doesn't work and I'm not exactly on friendly terms with the dealer any longer. The SAT still works just like when I first installed it so I should have saved the trip to the dealer. Quick shifts, holding the gear longer and a nice heavy steering but I still don't see anything on the display, which I can live with. The dissapointing part is that I dont get the rev matching when in manual mode!
#110
If your dealer received a VO code that didn't remove the standard auto trans, the vehicle does not behave nicely (possibly leading to the comment about nearly blowing the central control unit).
Sorry you're having trouble with the coding... hopefully you can get it sorted out!
______________________________
2008 550i M-sport
2006 X3 2.5i
1998 528i (retired)
