Retrofit Aux Coding problems - 5Series.net - Forums
E60 Parts, Accessories and Mods Discussion about both stock and aftermarket parts for the E60. Accessories and modifications too!
Old 10-19-2018, 11:11 AM
My Ride: 545i
Default Retrofit Aux Coding problems
Hi All.
New to 5 series and new to the forum.
I just bought an 04 545i and installed an aftermarket aux cable.
I'd like to make clear, I have spent hours reading through posts across loads of forums trying to see where I have gone wrong. So I'm only posting my own question out of desperation!
I used Roskinc's tutorial and added +NAUX to the vehicle order, and I then used the Revtor profile to code the aux in.
When I read the ecu the Aux is now showing as mounted - before coding it was showing as not mounted. If I try to code it as aktiv it shows and error and won't code it.
BUT - It still isn't showing in the entertainment menu.
I have the CCC wide screen Navigation unit.
I wrote the Vehicle order to CAS and LAM.
I updated the daten to a later version.
I don't know what else I can do to try to get it to work?
Dweed144 is offline
Old 10-20-2018, 06:50 AM
My Ride: 2008 BMW E60 535i
Model Year: 535i 2008
1) Use a different profile ExpertMode for example
2) update your spdaten
3) if you still have problems i can do this for you remotely
Impac is offline
Old 10-20-2018, 06:57 AM
My Ride: 545i
Thanks Impac.
I've updated the spdaten with the download from bimmergeeks.net (60.1)
I will try with a different profile.
How would you do it remotely? Would you charge for that?
As an update to the above - still no luck!!
Dweed144 is offline
Old 01-23-2019, 10:28 PM
Vlad525's Avatar
My Ride: E60 525DA
Engine: 525 M57 straight six @225BHP
Dweed, you can try coding it manualy with NCS. In CAPPL, search for AUX and set it to active. Or you can try to add $6FL to VO, FA write CAS, CAPPL and LMA then sgcodiren CAS, CAPPL and LMA. Or i can help with remote coding via teamviewer.
Vlad525 is offline
yellowbrick2000
09-30-2013 10:48 PM
545iMike
DIY: Do It Yourself
13
04-12-2013 05:11 AM
JerzyBoy973
08-20-2012 03:48 PM
silver_e60
07-18-2012 11:23 AM
Peter530i
04-07-2006 04:19 PM
Quick Reply: Retrofit Aux Coding problems
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
