RETROFIT 6FL/USB AUDIO TO E60 PRE 2007/03
#32
My Ride: E60
My Ride: E60
According to realoem.com this part isn't the ulf High you want.
RealOEM.com BMW E70 X5 3.0sd Charging electronics, hands-free
#35
Thanks for the quick reply I finally found it under Audio, Navigation, Electronic Systems => Radio adapter tubing.
Go figure!
Go figure!
#36
My Ride: E60
Could someone help me on the below problem. I have a 2004 E60 with ccc and have retrofitted the 6FL option in my car. I have successufully coded the 6Fl option and the usb audio works great through NCS expert. But unfortunately i have lost my bluetooth phone. No matter what i tried i can't code the bluetooth. There is no communication with ULF high even though usb audio slot works great. Do i have to make some kind of upgrade - programming to the ccc through winkfp and what to program? Thanks, in advance guys.
#37
My Ride: e60 530dA
srry for bump old post
i got e60 2004 with ccc too
sparky can you tell my how you code 6FL ?
you add 6FL option to FA in CAS and LMA ? I need to write +6FL or someting like that?
nothing more ?
My Cappl is 04 only (mp3 dont work)
nothing more ?
#38
#40
My Ride: 530i SMG
I may be very slow or do not understand after going through the tread. I have also 06/530i with CD changer. In my case all I added wad the Dension-500 module and no programming was needed. I was able to have USB, AUX, B-Tooth, and i-Pad interface all using i-drive and steering wheel interface.
Do we need to do any thing else. Am I missing some thing please help
