E60 Parts, Accessories and Mods Discussion about both stock and aftermarket parts for the E60. Accessories and modifications too!
Removing rear deck
Old 01-13-2010, 08:02 PM
anyone know how to remove the rear deck i have an e60 2006 525i obviously our seats dont fold down.
i know theres a way to remove it but im not sure how, some have said there are bolts under the seat that come off but i want to know if anyone has done it
thanks
rjcastr is offline
Old 01-13-2010, 08:14 PM
Gene's Avatar
just as an fyi: it's called the parcel shelf...
https://5series.net/forums/index.php?s=&amp...st&p=264281
please, take the time to search a bit before posting....a lot of your q's have been asked and answered before....
Gene is offline
Old 01-13-2010, 08:26 PM
this looks to be right but its not, in that pdf the rear seat is alrady removed before getting to the parcel shelf.
So i guess i will search removing rear seat lol first
rjcastr is offline
Old 01-14-2010, 05:47 AM
Gene's Avatar
did you look at the link the Rudy provided before opening that pdf?
As Rudy stated before he posted that pdf....
"First, take a quick look at this thread since there is a photo that may let you see what you're looking for:
http://forums.e60.net/index.php?showtopic=8584 "
Gene is offline
Old 01-14-2010, 06:24 AM
My Ride: 2010 VW Passat Wagon 2.0l Tsi Grey/Grey Budapest 18" Lost to HPFP issues: 08 535i sport pkg Lost to Dreaded E61 Sun roof leaks: 07 E61 530Xi
Yes it can be removed....
And it involves more than just removing the rear seat...
You will also need to take off the "C" pillar cover, and there are Air bags under there.
Order of removal
Rear seat bottom
Rear seat Back
"C" pillar covers
Rear Deck ( your not fitting any packages back there)
I removed mine to install the manual Rear sun shade on my 08 535I. It took about 2-3 hours to do the first time.
Be careful with the Airbags and the Clips that hold the trim , they are very easy to break.
If your car does not have removable rear seats you will
need :
BMW Trim removal kit
A good set of Torx Bit Drives
Drive extender
Socket wrench
Large Flat head.
When all the bolts are out you will still have to be very careful with the deck since there are speakers attached to it. I did not see any quick disconnect style attachments on said speakers , so you may have to have a soldering Iron or the like to reattach the wiring to the speakers.You will also have to come from inside the trunk to trip the two safety latches that hold the back seats tight ( normally these same latches have releases for the fold down seats). This comes before the trim removal and the deck removal. This is what the large Flat head screw driver is used for.
bigbadbull is offline
Old 04-08-2019, 08:35 PM
My Ride: e60 2006 530i 160k mi 6hp19 n53
Engine: n53
Is it a stretch to replace it with a 5.25 ? I keep looking for videos to see under there. all the links are dead.
azmalu is offline
sfcacique
10-23-2018 06:35 PM
rteone
04-07-2015 11:48 AM
Sibby1979
03-18-2015 05:27 PM
gonzo40
26
04-15-2005 08:26 AM
Jimbo
DIY: Do It Yourself
31
08-22-2004 12:47 PM
Quick Reply: Removing rear deck
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
