anyone know how to remove the rear deck i have an e60 2006 525i obviously our seats dont fold down.
i know theres a way to remove it but im not sure how, some have said there are bolts under the seat that come off but i want to know if anyone has done it thanks |
just as an fyi: it's called the parcel shelf...
https://5series.net/forums/index.php?s=&...st&p=264281 please, take the time to search a bit before posting....a lot of your q's have been asked and answered before.... |
https://5series.net/forums/index.php?s=&...st&p=264281 please, take the time to search a bit before posting....a lot of your q's have been asked and answered before.... this looks to be right but its not, in that pdf the rear seat is alrady removed before getting to the parcel shelf. So i guess i will search removing rear seat lol first |
So i guess i will search removing rear seat lol first As Rudy stated before he posted that pdf.... "First, take a quick look at this thread since there is a photo that may let you see what you're looking for: http://forums.e60.net/index.php?showtopic=8584 " :rolleyes: :whistle: |
Yes it can be removed....
And it involves more than just removing the rear seat... You will also need to take off the "C" pillar cover, and there are Air bags under there. Order of removal Rear seat bottom Rear seat Back "C" pillar covers Rear Deck ( your not fitting any packages back there) I removed mine to install the manual Rear sun shade on my 08 535I. It took about 2-3 hours to do the first time. Be careful with the Airbags and the Clips that hold the trim , they are very easy to break. If your car does not have removable rear seats you will need : BMW Trim removal kit A good set of Torx Bit Drives Drive extender Socket wrench Large Flat head. When all the bolts are out you will still have to be very careful with the deck since there are speakers attached to it. I did not see any quick disconnect style attachments on said speakers , so you may have to have a soldering Iron or the like to reattach the wiring to the speakers.You will also have to come from inside the trunk to trip the two safety latches that hold the back seats tight ( normally these same latches have releases for the fold down seats). This comes before the trim removal and the deck removal. This is what the large Flat head screw driver is used for. |
Is it a stretch to replace it with a 5.25 ? I keep looking for videos to see under there. all the links are dead.
