Pre-LCI Halogen to Pre-LCI Bi-xenon AHL
5 Attachment(s)
March 2012, I purchased a pair of dynamic, Bi-xenon headlights to replace my halogen ones. The set was already a steal at $510 but they also came with the xenon and adaptive control modules! I successfully coded VO 522 to my car and had been using the headlights for two years without adaptive functionality. I recently thought. What the heck…it would be nice if the auto leveling and adaptive features also worked! So. I started my research….
Pair D2S HID bulbs$64.00 Pair of 2005 e60 bi-xenon AHL headlights w/ adaptive and xenon modules$510.00 left and right adaptive harness$130.50waste LM 61359154944$165.00 cloth friction tape (3x)$14.25 20 AWG wires - 8 colors 25' each$31.97 two level sensors$65.20 sensor install kit$46.64 housings and wire contacts$21.55 bushing contacts (14) housings (1)$52.34 ground contacts$5.00 16 AWG wire 25'$12.00 wire connectors10 Total damage to wallet$1,128.45 Previous upgrades: 1. Rear backup camera 2. CD changer 3. Interior from Wood grain to brushed aluminum 4. Brushed aluminum foot plates 5. LED interior lighting 6. 19" wheels 7. Rear PDC 8. Amp and subwoofer 9. Dynavin DVN-E60 touchscreen 10. aux cable 11. sport mode |
hi! xonreh
It is a very good job! I am also working to retrofit adaptive headlights. Now, most functions is working properly. Two questions here · Did you follow the connection of 71 & 72 PIN fromPT-CAN? · Did you follow the correct connection of the LIN-BUS 16PIN from RLS? It does not establish a complete action If you do not do this connection? Thanks! |
e60 dynavin
Originally Posted by xonreh
(Post 1539631)
pm sent
Originally Posted by star69me
(Post 1543932)
Hey how is the dynavin unit does it do everything it says. Are the graphics good. Where did you get yours
Was it worth it?
(Post 1539631)
Running the wire - I didn’t know the length of the wires for each run to various places so I just ran the cables and cut them to the length I wanted. My biggest issue was running wires to the passenger headlight. I decided to remove the air filter housing and open the fuse/adapter box beneath it. Using the old ‘hanger tied to the wire’ method, I pushed the hanger thought to the fuse box. I then poked a small hole through a rubber protective cover from the fuse box and pulled my wires through to the headlight and tire well. There was nothing tricky about running the other wire, just a lot of work.
Materials Pair D2S HID bulbs$64.00 Pair of 2005 e60 bi-xenon AHL headlights w/ adaptive and xenon modules$510.00 left and right adaptive harness$130.50waste LM 61359154944$165.00 cloth friction tape (3x)$14.25 20 AWG wires - 8 colors 25' each$31.97 two level sensors$65.20 sensor install kit$46.64 housings and wire contacts$21.55 bushing contacts (14) housings (1)$52.34 ground contacts$5.00 16 AWG wire 25'$12.00 wire connectors10 Total damage to wallet$1,128.45 Previous upgrades: 1. Rear backup camera 2. CD changer 3. Interior from Wood grain to brushed aluminum 4. Brushed aluminum foot plates 5. LED interior lighting 6. 19" wheels 7. Rear PDC 8. Amp and subwoofer 9. Dynavin DVN-E60 touchscreen 10. aux cable 11. sport mode as I’m buying new headlights anyway, would it be beneficial to upgrade to bixenins at the same time? Do gheh bake much difference to vision at night? Lots of twisty mountain roads on the island I live on thanks |
Hey,
I know this is an old thread but does someone still have those documents or guides on how to retrofit bi-xenon AHL? I would like to have a diagram of how the headlight level sensors need to be wired and what is needed to get the adaptive headlights to work. Thanks. |
