Notes on a 2009 535i HiFi to MS-8 install
#81
My Ride: 2010 535i xdrive
Model Year: 2010
contact Technic or search for used parts.
Enhanced Premium Sound/Logic7 Plug 'n Play Trunk Subwoofer Harness - Bimmerfest - BMW Forums
#82
My Ride: E60 (LCI) M sport, Lane departure, Bluetooth, Xenons.
Engine: M57
Hi is there a way of adding the central speaker even if I have a basic head unit (no amp in trunk) and originally only had 6 speakers in my car? I'd love to get a juice for the speaker from somewhere without disturbing the L - R balance. I may be naive to think that it's doable, but you guys seem like you know a trick or two about it so here I am asking a dumb question
#83
Engine: M57
Plug MS-8 to input/output M-ASK extension cables (front, center and rear speakers) and to OEM amp input and output underseat woofers signals (cables pre-terminated for PnP):
Notes:
1) MS-8 uses the 12V and ground connections from the OEM amp via the PnP harness. The OEM amp 12V is a 40A fused OEM line; the MS-8 is double-fused at 25A. No whine, no noises.
2) Result: quite an inprovement in clarity, front stage focus, bass impact and overall loudness despite the OEM speakers. This should not be any secret or magic: power was increased from 25W x 4/40W x 2 to 60W max x 7, adjustments went from just bass/treble to bass/mid/treble, sub and center level, Logic7, and 31-band EQ while the M-ASK outputs EQ curve flattened. So there are enough possible adjustments to get a relatively louder and clearer sound than OEM. The addition of the DLS 424 center channel and particularly the Logic7 processing created a higher, adjustable (driver/passenger/front focused) and just better front stage that was not there before.
Customer was very happy with the result, so I was happy...
Notes:
#84
I'm sorry to revive an old thread; I got my 2010 535i last September (2022) I've installed a 10.25" Android screen in place of my 6.5-inch factory screen, and I have a pair of subs running free-air off a Kicker 800.1... I had to cut the pass-through as I have the solid-backed seats
I have the HiFi system, (Woofer amp and 8 speakers in the cabin powered by the head unit)
I have a few questions...
1. for someone trying to do all this now, what current equipment is available to achieve what the MS8 and CleanSweep did years ago? I don't necessarily need a center channel if I can get the time alignment done in the DSP
2. I want to add power to my cabin speakers and possibly DSP, but definitely more adjustability, what are my choices without having to re-run ALL of the speaker wires?
3. I've already tapped into the woofer amp to provide a signal to an amp in the trunk, but is the signal for the underseat woofers bandpassed from 30-500Hz or is it low-passed (or full range)? (I want to make sure my subs are playing as low as flat as possible)
#85
My Ride: 2006 BMW 530Xi Touring
#86
My Ride: 535xi Wagon
Model Year: 2010
Also if you really want to get into the rabbit hole this is a great thread to read and will apply to your car.
Audiotec Match UP 10DSP Amp as PnP Upgrade Solution For HK Equipped Cars?
bruce_miranda
04-15-2015 03:25 AM
