not bad for pre-lci halogen
My Ride: BMW E60
Model Year: 2016
http://www.ddmtuning...10-168-LED-Bulb i got these ones 3W CREE bulb, i will keep you guys updated to let you know if it gets to hot, or burns out quickly... for now i love it
http://www.ddmtuning.com/Products/HP...0-168-LED-Bulb i got these ones 3W CREE bulb, i will keep you guys updated to let you know if it gets to hot, or burns out quickly... for now i love it
You need a lot bigger heatsink to cool a 3w LED, they are fine for reverse lights, but not on all the time.
I have tried a lot of LED bulb and some litteraly fall apart over time because of the heat.
Try this: set power to the bulb, hold it in hand (bulb still on) if you are NOT able to hold it an infinite amount of time, then it is getting to hot.
This only works with LEDs, a halogen bulb is a different matter.
If you are able to code your car via NCSExpert, then there is an option to turn of the outer bulbs if the low-beams are on.
This will help the LED not overheat, because the low-beam halogens are very hot. And you canīt really see the outer ring if the low-beam are on anyway.
My Ride: 2006 525i
yes very true, I'm sure the 2W one's are bright also but i saw the 3W cree and couldn't pass them up lol
Nice bulbs, but these will properly fail over time, You need a minimum of a 30x30mm heatsink.
i agree 100% i figured id buy em just to try em at least, most of the time i drive with just my fogs and parking lights on anyway so the low beam isn't a concern that much , unless I'm on backroads. Passed a few cops and they seem to not think anything of it hahaha but can you let me know where to do that code. I am into coding and have NCSExpert and INPA but wasn't aware of that !
My Ride: 05 525i xenons, premium package, non-nav
Black360 exactly which hid kit for your fogs did you purchase from ddm? I'm looking at getting 6000k kit just like you but not sure between 35w and 55w kit? And did u purchase the error cancellors?
My Ride: 2006 525i
i got 35W Slim ballast no issues whatsoever and i got the error cancelers also , even know i coded out the bulb checks on my lights i still got them for good measure and no errors on dash at all (even before i coded it) and they are 6000K they look great in person !
There's a note somewhere in DDM site that suggest the 55w kit is not recommended inside a small space like in a fog light due to heat.
Hi, i believe itīs "PWM_ANSTEUERUNG_SL_V_AL" that should be set to "wert_02" = outer rings turns OFF when low-beams are ON.
There is a similer one for the high-beams, the inner rings, itīs just "PWM_ANSTEUERUNG_SL_V_FL",
You will find these in the LMA.
Do you have problems with the rings "strobing" or flashing when you turn the ignition on?
My inner rings are flashing and I have set all of the LMA checks to inactive. (nicht_aktive)
KALTUEBERWACHUNG_SL_V
WARMUEBERWACHUNG_SL_V
FEHLERMELDUNG_CC_SL_V
Very annoying, my lights are quite powerfull at night and it looks "cheap" with this start-up lightshow.
My Ride: 2006 525i
My Ride: 2006 525i
