E60 Parts, Accessories and Mods Discussion about both stock and aftermarket parts for the E60. Accessories and modifications too!
Need help with Angel Eye voltage / measurement.
Old 01-13-2009, 04:24 PM
Hi All,
Does anyone know the correct voltage for the angel eye bulb?
I'm trying to work on something and put a few LED's in place of the single angel eye bulb.
I have these 3.3/3.6v LED bulbs
Specs:
FW current: 25ma
FW Supply: 3.3v (Typical), 3.6v (max)
LED from radio shack, Part# 276-0017.
I would like to have two of these connected to the angel eye portion. Now what resistor would I need in order for the bulbs to work and the car would not give an error message?
Please help!
Thanks in advance!
nigxdoof is offline
Old 01-13-2009, 04:26 PM
My Ride: 14 550i
You have a multimeter or voltmeter?
Originally Posted by nigxdoof' post='767181' date='Jan 13 2009, 05:24 PM
Hi All,
Specs:
FW current: 25ma
Please help!
Thanks in advance!
acuteperformance is offline
Old 01-13-2009, 04:32 PM
Nope.
If I have that and measure the voltage with the volt meter, can i use it to calculate what resistor I need?
nigxdoof is offline
Old 01-13-2009, 04:36 PM
nigxdoof is offline
Old 01-13-2009, 04:41 PM
My Ride: 14 550i
theoretically yes. Resistance (Ohms) = Voltage (v) / Current (I)
Originally Posted by nigxdoof' post='767193' date='Jan 13 2009, 05:32 PM
Nope.
Old 01-13-2009, 04:45 PM
Time to go back to radio shack..
nigxdoof is offline
Old 01-14-2009, 06:16 AM
Banned
My Ride: A Car
mike. how r u trying to wire it? man, it;s too much work....
John@Motorcepts is offline
Old 01-14-2009, 06:43 AM
My Ride: 2008 550i manual
Engine: V8
this looks promising
Ghostteck is offline
Old 01-14-2009, 07:41 AM
Brit_in_NJ's Avatar
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather. Mods: Carbon filter removed. M5 iDrive knob. Umnitza license plate LEDs. MP3 40% 3M tint ACS Anti-Roll(sway) bars RPI Scoop G-tech Pro RR CF Roundels CF Wheel caps
Virtually everything is going to be just over 12V (probably about 14 I'd guess)
You need to measure the current in the OEM angel eye (place your meter in series) to then calculate the size of the resistor using the equation above. Once you have the resistor size to match OEM and if you have a few resistors of various sizes you could swap them out until you get the smallest current draw (highest value resistor) before the iDrive error.
Since the iDrive strobes the bulbs when they are not switched on I was playing around with a capacitor in the circuit to fool the iDrive into believing there was a load there. If I ever get the time I will get to test it in the car.
Brit_in_NJ is offline
Old 01-14-2009, 09:00 AM
Cool. Good info Rich, Thanks.
nigxdoof is offline
Quick Reply: Need help with Angel Eye voltage / measurement.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
