Mulf2 High USB Problems
Hi guys,
I successfully retrofitted Mulf2 High in my car and I was using the USB outlet all the time until yesterday when it just stopped working.
I've checked the cable, the USB outlet, everything seems fine. I've made another cable, around 30cm. to see if the cable is not too long but again it doesn't work.
When I insert the USB stick the LED of it starts to glow, but it doesn't flash at all which means there is no data transfer. If I insert my iPod (which I've tried when I retrofitted the module few days back and it worked) it doesn't work also, it is not syncing, charging or anything, like it is not plugged in.
The Bluetooth works fine, the AUX outlet also works, but the USB doesn't.
There was a fault code ( A9AB ) written into the ISPB module but when I deleted it it never appeared again.
Any help is much appreciated!
Awest91
09-17-2022 11:05 PM
chadillac2000
42
09-13-2017 11:15 AM
CertifiedOfficial
04-15-2015 12:03 PM
