M5 instrument cluster
Old 08-30-2017, 06:27 PM
  #131
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Originally Posted by alisaeed03
hey are are you able to code a pre lci e60 m5 cluster to a 2008 535i and have the cruise still working?
No so find a LCI.
Old 02-19-2023, 07:13 PM
  #132
MSB123's Avatar
My Ride: 2000 750iL, 2003 M-Tec 540i, 2009 535xiT
Wondering if anyone has a solution for CC on a m5 cluster. I have a 535 with standard cc as an option, and have yet to code it with ncs as I can’t quite figure it out.
Is there a step by step for how to code the cluster to work with an auto 535? Thanks!
Old 02-19-2023, 07:14 PM
  #133
MSB123's Avatar
Originally Posted by GTYellowJacket
I figure I’ll resurrect this discussion from a few months ago, because it looked like there was a lot of skepticism about getting this to work fully without errors, despite a few successes noted above. Well, I just did mine last night, and it’s functioning perfectly with no errors or tamper dot.
I purchased a March 2009 M5 cluster for my 2010 LCI wagon (born July 2009). I removed and resoldered the EEPROM to flash my VIN and clear the miles. After flashing the EEPROM but before coding, my cruise control was not functional, and I got the typical errors for transmission, EDC, and several others. Then I simply coded it with my custom MAN file from my original KOMBI and everything works. No errors, correct red line, correct oil temp, and transmission [P, D, R, gear] reports as the original cluster did, including with the SAT retrofit function.
I’m curious to see if there is a pre-LCI difference, so if anyone has a pre-LCI cluster (or LCI for that matter) that they’re struggling with, I’d be happy to help (share BIN files, flash, etc).
would love these files if you still have them!!
bbbamboo
09-17-2017 04:33 PM
16g-95gsx
11-12-2015 01:46 PM
Luie
10-06-2015 03:01 PM
bestofthebest
10-02-2015 03:21 PM
ianbmwe60
08-23-2015 03:20 PM
Quick Reply: M5 instrument cluster
