LED REFLECTORS
#41
My Ride: 08 528i TiAg Premium/Cold Weather Pkg, 20% Tint, Technic Harness, JL Audio 12W7, JL HD 750/1 and LOTS of lighting mods!!!!!
If you follow the instructions I provided and cover all exposed wires you will be good.
It really is pretty basic wiring.
Video...
http://s75.photobucket.com/albums/i3...t=SDC17402.mp4
And this is what I have been working off and on on...
http://s75.photobucket.com/albums/i3...t=SDC13129.mp4
Functions the same as the one being advertised it is now a rod instead of 5 separate leds.
Have not worked on it for a while.
Still need to make it as bright as the rods on the lights though.
Video...
My set I installed are going well. My right side got water into it and shorted out the brake light unit which caused no lights to work on the vehicle. That was due to me not covering the wires correctly. $300 dollars later for ordering the new brake unit everything has been fine. No problems at all. I love them they give you more light in the rear which is need on dark roads.
#43
i've always wanted to get LED reflectors for my stock bumper but never liked the fact that there was only 5 LEDs in the middle of the reflector instead of running across the whole reflector. If they made LEDs run across the whole reflector or used a LED strip like you did I would def. get it. It looks a lot cleaner, good work!
#45
the ones u will tap into r...
ground
parking light
brake
this is a pic of the right (passenger) light wire set
i know for sure brown is ground and will need the green wire from the reflectors to be connected to it
id go into greater detail if i had my car with me (out getting painted after a small bitch boy knifed my car)
ground
parking light
brake
#46
My Ride: BMW 528I
Model Year: 2010
some pics of before, during, and after
before
halfway
done!
night time pics!!
closer up
only thing i didnt like is that the hook they used on the back fell out after i had test fitted it and tried to take it out
it was a good thing i had another reflector laying around so i used it's and put some epoxy on it and the other side aswell (just in case)
before
halfway
done!
night time pics!!
closer up
bestofthebest
03-28-2016 02:47 PM
Bogdan7
09-23-2015 11:40 AM
umnitza
09-02-2015 11:28 AM
