How many here use 10w60 oil
Old Mar 5, 2010 | 02:15 PM
miguex's Avatar
From: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
I do! I use 10W60 on my 545i for 2 years! Highly recommend! it protects the engine (I know is is for M cars because of high RPMs... Well, I do high rpm too! I tested both Castrol 5W30 and it ok and I feel little slowly... then an pro-racing mechanics recommended me to use 10W60 and it converts a beast! Hands down! Ask any professional racing mechanics... I bet they will tell you to use 10W60 regardless the car is not an M.... it is like BMW does not want to install LSD on non-M cars, so same for oil... I thing all V8 must use 10W60 if you revving high..
Yes, I know BMW says don't use 10W60 on non-M like they said don't remove the charcoal filter. same thing!
Old Mar 5, 2010 | 02:22 PM
miguex's Avatar
Originally Posted by tiangco.a
chime in miguex...
lol... you know BMW V8 should use 10W60 and you know Mark and Yuri at Autowerks here in Calgary. I have using it for 2 years! the car runs very smooth and like new still!.
Old Mar 5, 2010 | 06:04 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
thicker oil makes the oil pump work harder, and lowers your fuel economy.
//M engines are designed with different tolerances, which is designed for a heavier oil.
most normal cars are designed for fuel efficiency, hence the tighter bearing clearances and use of thinner oils.
you gain nothing by using a thicker oil.
Old Mar 23, 2010 | 06:45 AM
response_surface's Avatar
My Ride: 2005 545i Sport 6 speed Manual
i am considering the the 10w60 too, i think they are spec'ing the thin oils for fuel economy at the expense of engine protection. seems like if its ok for a bmw v10 then why not a bmw v8.
so it seems you've had no probs using that oil?
Old Mar 23, 2010 | 08:45 AM
KREED_550i's Avatar
My Ride: 2006 550i | Silver-Grey- A08 | Premium - Sport Package | Adaptive Headlights | Logic 7 w/ CD Changer | Bluetooth | Park Distance Control | Xenon Headlights | Comfort Access [s]Sprint Booster V1[/s] | K&N filter - Stock Box w/ Charcoal Filter Removed | Clear Side LED Markers | Matte Black Grilles | RPI Air Scoop | RPI 550i GT Exhaust | 12" Kicker w/ AMP | Headlight Euro Overlays | ACS Rep Roof\Trunk Spoilers |MTEC V2 Angel Eyes | 6000k HID Fog Lights | 19" VMR v710 Stag Wheels | Hankook Ventus V12 Evo K110 Tires | Debadged | LED Courtesy Door Lamps | Sprint Booster V2 | Painted Calipers | M pedals\shift knob | HID License Plate Bulbs | R1 Drilled\Slotted Rotors | Hawk HPS Brakes| ACS replica front lip |
I've heard of Purple Stuff oil? Does anyone use that? Heard it was good performance oil.
Old Mar 23, 2010 | 10:58 AM
turboawd's Avatar
Thicker oil doesn't flow as well or get into tight clearances as well. And since there's lower flow it doesn't carry heat away as well.
plus lower fuel consumption, and working the oil pump harder.
most engine wear ocurrs at start-up. a thinner oil will flow better when cold.
Vman33
Mar 14, 2022 04:43 AM
bestofthebest
Mar 28, 2016 02:47 PM
fabolous531
Oct 18, 2015 12:22 PM
snoop
Sep 26, 2015 05:28 AM
subieworx
Sep 21, 2015 01:19 PM
