How to code Xenon lights into E60 525d
Old 06-28-2018, 03:28 PM
Hashim's Avatar
My Ride: E60
Default How to code Xenon lights into E60 525d
Hey there,
A friend recently upgraded his 2004 E60's halogens to Xenons, and asked me to sort the coding out for him. I've previously set up and coded things for him so I have NCS Expert set up and ready to use on my laptop and am aware of how to use it, but I've never changed the VO. The research I've done says that $522 is the code that needs to be added to the VO number to enable Xenons. Which module(s) does this VO need to be added to for an E60, and once I've done so successfully, is there anything else that needs to be done? Hoping to get some input from people that have already done this on an E60.
Thanks in advance, it's much appreciated.
Old 09-10-2018, 02:24 AM
vmann's Avatar
My Ride: BMW E60 M5
I've done this conversion in the past. Just use NCS expert to code it. You will find the right code on the internet. Also you will find a link where you need to modify two wires, google e60 xenon to halogen conversion. But it will need to be coded for it to work correctly. The only thing that won't work is the adaptive side of it, if your headlights are adaptive.
Old 09-12-2018, 07:04 AM
Impac's Avatar
My Ride: 2008 BMW E60 535i
Model Year: 535i 2008
Add $522 to VO CAS/LMA and recode LMA default
kilinho
06-16-2016 04:23 AM
kerrys914
04-01-2012 10:20 AM
smimhee
11-07-2008 02:26 PM
BigGrey
12-07-2005 04:57 PM
soc_fans
25
11-10-2005 08:40 PM
Quick Reply: How to code Xenon lights into E60 525d
