Handbrake ASZE Problem
My Ride: BMW 535d Touring
Hi guys
I seem to have got myself in to a bit of a situation.
I decided to replace the rear pads and shoes as the pads were showing around 2k left (and I do a few miles hundred miles a month) and the handbrake wasn't very effective,
I did the first side okay, but then on the second side the cable seemed to go slack.
Now I have no handbrake at all. Its an auto so its not too bad on the flat. But really want it sorting.
I had searched for how too's on this prior to starting and it seemed straight forward, it was only when this happened I heard of the ASZE (auto adjust thing) and how I should of obviously done something prior to starting.
Anyway, I didn't what can I do to sort it?
Please help, this may put me off trying anything mechanical again. My last car I could do anything with, this ones difficult.
Many thanks in advance
Tim
Tim
Right then. I sorted it. Might as well post reply to myself here just in case anyone falls in to this trap.
Fortunately I think the car helped me out doing what I should have done myself. Under the handbrake lever is a pale blue spring, this must tension the cable, in the middle running though is a silver clip. The idea is you compress the spring and move the clip across to hold it (what I didn't do). This releases some cable to allow you to replace the shoes more easily. To re tension the cable compress the spring a little then move the clip over to one side. Voila, spring releases and cables are taught.
Hi guys
Tim
Tim
Beemer
33
01-14-2019 05:13 AM
