Fog Light Restoration Makeover
Old 08-29-2009, 01:17 PM
socale39's Avatar
My Ride: 545I SMG
After pulling off my stock front bumper in place of the Umnitza M5, my OCD overwhelmed me and I immediately had to seize all efforts once I saw my fogs. Simply put, I couldn't install a freshly painted bumper with old looking fogs. So I decided to give my fogs a makeover and here are the results...
Before OCD:
After OCD:
Side by side:
Sure beats buying a new set!!!
Old 08-29-2009, 01:22 PM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
I have to google it: Obsessive?compulsive disorder (OCD)
So, how did you fix it?
Old 08-29-2009, 02:00 PM
BALASUBAS's Avatar
yeah what did you use to clean it?
Old 08-29-2009, 03:34 PM
socale39's Avatar
My Ride: 545I SMG
It takes some time but here are the steps:
1) sand with 800 grit
2) sand with 1000 grit
3) sand with 2000 grit
4) polish with compound (menzerna power gloss)
5) polish with fine compound (menzerna intensive polish)
6) seal with wax
Old 08-29-2009, 03:46 PM
Alpine White Girl's Avatar
6) seal with wax
going to try the same process on my windshield. be back in 10 days
btw nice work on the fogs they look great.
Old 08-29-2009, 04:50 PM
luigi524td's Avatar
Originally Posted by Alpine White Girl' post='992628' date='Aug 29 2009, 07:46 PM
I don't think I'd try to restore / polish the windshield in this manner ... an error on a fog priceless - a mistake on a windshield pricey!
Old 08-29-2009, 04:54 PM
CWS530's Avatar
Very nice result. I'm the same way. Every little mod has required double or triple the time so I could clean, polish, whatever, when I pulled off the original piece . My fog lense could use some work. They have a few pits. Thanks.
Old 08-29-2009, 08:07 PM
socale39's Avatar
My Ride: 545I SMG
If you guys do this don't be afraid. When you sand the lens it will look really foggy and you'll wonder how it'll polish out but it will. Also, use wet sand paper for this job and keep the lens wet when sanding.
Old 08-29-2009, 08:14 PM
Gene's Avatar
6) seal with wax
similar to the same process as the headlight restoration DIY's we have here also correct?...which I believe you also did correct?
great results, nice work
Old 08-29-2009, 08:34 PM
socale39's Avatar
My Ride: 545I SMG
Yep, I've done few headlight restorations for detailing clients and friends. Its the same process.
Quick Reply: Fog Light Restoration Makeover
