good god that is brilliant... i have the same headlight as yours, definitely would like to have similar
does your angel eyes still works? or blacking out the angel eyes making it not visible anymore? |
Originally Posted by Dra530i
(Post 1575819)
well noted! mind sharing where you get the genuine mounting tab repair kit and headlight gasket?
thank you |
(Post 1575834)
thank you Evan |
amazing work.
question...how do the high beams work if you've painted the reflector black? |
Originally Posted by BostonJon
(Post 1576037)
amazing work.
question...how do the high beams work if you've painted the reflector black? No the oem high beams do not work, I disconnected the bulbs. The projector is bi-xenon and has a high beam that would embarrass the oem reflector bowl. Evan |
another question....
when you say, "Projector rotation finalized and locked in with epoxy"... how do you do this when everything is taken apart? do you need to be able to power them on to make sure they are in the proper rotation? edit: holy sh*t man, i just saw your other post about the engine failure! sorry to hear that. |
(Post 1576076)
when you say, "Projector rotation finalized and locked in with epoxy"... how do you do this when everything is taken apart? do you need to be able to power them on to make sure they are in the proper rotation? edit: holy sh*t man, i just saw your other post about the engine failure! sorry to hear that. In this case I had E60 lights and an E61 to fit them to so I used my wagon to test fit and at this point the headlights still have the lenses and most interior trimmed, essentially it is the headlight housing with the projector mounted to it in a way that I can access and adjust to finalize the rotation, much like in my initial post where the picture description reads, "black on black.' Yes you need to power them on and ideally on the actual car which they go on. You can create jigs to align headlights off the car but it can be very tricky. Evan |
Projector
Nice Mod!!!
If i were to buy a new projector,do i have to use a new bulb? I'm currently using d1s lci bulbs. And also,where do you buy this thick shrouds that goes around the lens? Thanks!!! |
