Dopey Mechanic Removed Brake Sensor "Receiver"
Old 08-22-2018, 06:04 AM
beekir's Avatar
My Ride: E61 530Xi MT
Angry Dopey Mechanic Removed Brake Sensor "Receiver"
I've been struggling for two days to replace my front brake pad wear sensor. The first day I struggled because I had confused the ABS sensor with the brake sensor. The second day I figured out that the receiver that I'm supposed to plug the sensor into has been completely removed from my car by a dopey local mechanic.
When I open up the box that should have both the blue ABS connector and the white brake wear connector, only the blue ABS connector is present. The white "receiver" collar is completely missing from the box, so I've got nothing to plug the new wear sensor into.
I removed the wheel well splash guards and started peeking around to see if the cable had been stuffed up inside for some stupid reason, but it appears to have been completely removed from my car.
Can anyone tell me: 1) What is the part number for the "receiver" side of the front brake wear sensor, and 2) Where is it supposed to run and what does the other end of the harness plug into?
EDIT: I'm such an idiot. I was looking on the wrong side of the car!!
Old 08-23-2018, 05:15 AM
NoQuarter's Avatar
Engine: N54
Are you sure you are not looking on the wrong side of the car? ... Go look at the other side
Old 08-23-2018, 07:12 AM
beekir's Avatar
I'm going to smack myself if I'm looking at the wrong side of the car... Will report back
Old 08-23-2018, 08:17 AM
NoQuarter's Avatar
Engine: N54
If it turns out to be on the other side... welcome to the "idiot" things we do!
https://bmw.spoolstreet.com/threads/...an-idiot.3522/
Old 08-23-2018, 10:38 AM
beekir's Avatar
I definitely look like an idiot on this one. I already hassled my mechanic over "his mistake," but today at lunch took a look behind the front driver-side wheel... There are two cables there!
I guess for my year E61, the front wear sensor is on the (US) driver's side and the rear wear sensor is on the passenger side. I swear somebody told me the front sensor was also on the passenger side...
Excited to go home and get this sucker installed so my brake light & on-screen warning will finally shut off after all these months. After that, I only have half a dozen more repairs to go...
Old 08-23-2018, 10:45 AM
NoQuarter's Avatar
Engine: N54
Glad you got it sorted out!
Be sure to check out spoolstreet too. A lot more support over there these days
Old 06-15-2021, 10:59 PM
ernismuriqi's Avatar
My Ride: 5 series
i have the same problem here but for the left rear side of my E60 only the blue receiver is visible and the white receiver is completely missing inside the small box when you connect the sensor
Old 07-10-2022, 12:35 PM
Flguy76's Avatar
My Ride: 2004 BMW 530i
Model Year: 04
Engine: M54 3.0L
my us 04 530i has it on front passenger side.
bryanread
07-01-2014 08:18 AM
Almighty JungleBoy
Bluetooth & Cell Phone Forum
01-16-2006 08:27 AM
mtosca
07-15-2005 02:27 PM
tedmundson
10-28-2004 12:40 PM
Quick Reply: Dopey Mechanic Removed Brake Sensor "Receiver"
