Clunking noise when I set my coils too low - 5Series.net - Forums
E60 Parts, Accessories and Mods Discussion about both stock and aftermarket parts for the E60. Accessories and modifications too!
Thread Tools Search this Thread
Old 05-09-2017, 03:07 PM   #1
My Ride: 2008 535xi, 6 speed manual, jb4 tune, ISC coilovers
Default Clunking noise when I set my coils too low
So I just got ISC Coilovers for my 2008 535xi and I put them down fairly far, just so the fender was slightly lower than the top of the tire with stock wheels and tires, and now there is a clunking noise when I drive that increases with speed and continues when I am in neutral. I am pretty sure that it is axle bind because it went away once a raised the coils up. Once I get bigger wheels I am hoping it will not even happen when I get the coils set where I want them; but does anyone have any other ideas on how to fix this? Or know if it could be anything else? Thanks
liam_e60_535xi is offline   Reply With Quote
Old 05-16-2017, 08:53 AM   #2
My Ride: None
Model Year: 2012
Engine: N54
Did you replaced your strut mounts.
DILLESTJAMZ is offline   Reply With Quote
Old 05-16-2017, 11:35 AM   #3
You mean the collars that pinch around the bottom of the strut? No I didn't they're part of the main hub piece. The problem is only on the front by the way, I forgot to mention that in my earlier post.
Old 06-06-2017, 01:03 PM   #4
My Ride: None
Model Year: 2012
Engine: N54
Any solution, i dont understand. When i installed coils on my e60 i also had the clunk. i replaced the top strut mount and i put 2 washers instead of 1 then the bolt after. maybe make a video so we hear the noise.
Old 06-07-2017, 06:23 AM   #5
I did replace my top strut mounts ( they came with the coilovers) but i did not put in washers. Im not totally sure how it could be the strut mounts because the problem is related to how low i set my coilovers and the speed i drive, it has nothing to do with going over bumps.
I called the dealership about the front axles on my car and apparently I bought it with the wrong axles because the part numbers didnt match. Not only do i have the wrong ones, but the ones i have are the same length and part number side to side when they are supposed to be different so I am fairly sure this is the problem, I just have to order new axles but bmw ones are super expensive.
Old 06-12-2017, 09:03 AM   #6
My Ride: 2007 530XI
I had a similar issue when turning left while the ride height was set low. I adjusted my sway bar end links and it went away. You may need to lengthen the sway bar links.
AliensRGr8 is offline   Reply With Quote
Old 06-12-2017, 05:02 PM   #7
Thanks Ill check that out too. my coils came with adjustable ones so they should be easy to mess around with
Old 07-01-2017, 02:04 PM   #8
My Ride: None
Model Year: 2012
Engine: N54
Yeah you should always do an alignment after installing coils or any suspension!
Old 07-06-2017, 08:22 PM   #9
535DREAMER's Avatar
My Ride: e60 535xi Prem. Package
Model Year: 2008 535xi
Quote:
how did you lengthen them ? I am dealing with a similar situation.
535DREAMER is offline   Reply With Quote
Old 07-06-2017, 08:26 PM   #10
535DREAMER's Avatar
i think i need adjustable endlinks then
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content Copyright © 2012 by Internet Brands, Inc.
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
