CIC Retrofit Installation LOG
Old 09-03-2013, 08:22 AM
  #1001
ncsugrad2006's Avatar
I'd try saving current psw file first, then setting it back to defaults using process ecu and see what happens. Sorry, that's all I got!
Old 09-03-2013, 08:49 AM
  #1002
ptikkala's Avatar
yep, coded it with default settings and no more compressor error codes in ihka, seems to work ok. Now just need to study new ihka how to use it . Got warm and cold air, engine fan not always on... Hope that it works when it is supposed work
Old 09-03-2013, 09:03 AM
  #1003
Good deal. Do you have passenger side controls working? That has been an issue for others
Old 09-03-2013, 09:19 AM
  #1004
ptikkala's Avatar
hmm, pressing button changes airflow, high/center or legs, or combinations of those. And it brings up the passenger picture.
Old 09-03-2013, 09:20 AM
  #1005
Sounds pretty good to me
Old 09-03-2013, 10:37 AM
  #1006
ptikkala's Avatar
hmm anyone got partnumber for those plastic knobs on the panel? my panel got bit too much worn knobs
Old 09-03-2013, 10:40 AM
  #1007
I know they make replacement buttons--not sure on the knobs though
http://www.realoem.com/bmw/showparts...26&hg=64&fg=20
Old 09-03-2013, 12:37 PM
  #1008
ptikkala's Avatar
ok so just a little write up about my lci ihka install. Car is 530d 2006/01 (Ihka high from factory)with CIC retrofit. Everything was pretty simple, just do the wire mod which i desribed above (and ncsugrad provided great link), code ihka panel with default settings and as far as I know its all done. Tomorrow ill read the ihka again and check what differences there are between my default settings and lci ihka high donor.
btw. anyone know what happened to great bmwcoding.com forum???
Old 09-07-2013, 09:28 AM
  #1009
addy33's Avatar
My Ride: 550i
Model Year: 2011
Does anyone know if an F10 or F07 CIC Head unit fit an e60? I recently received an F07 Headunit and am attaching the pictures of it. I'm worried that I cannot find a the connector for the faceplate/volume control/buttons
Any help? I went ahead and opened the headunit and saw there is a red connector at the bottom left but its not being used. Do the faceplates on the F series attached to the third range/salmon connector at the back of the CIC?
Attached Thumbnails CIC Retrofit Installation LOG-dsc05346%5B2%5D.jpg   CIC Retrofit Installation LOG-dsc05345%5B2%5D.jpg
Old 09-07-2013, 11:42 AM
  #1010
awt
awt's Avatar
My Ride: 2001 320Ci Coupè
They will not work.
Quick Reply: CIC Retrofit Installation LOG
